Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: Tap off Cigarette Lighter for Amp Remote Wire?
    DaBurner's Avatar
    DaBurner is offline Member
    Jan 2006
    Long Island, NY
    147
    Guys this probably sounds so retarded but I had to ask, I've tried nearly every wire on my wiring harness and couldnt get a signal to my amp to turn it on so now im asking if I could tap off my cigarette lighter, and if I do could I risk damaging anything ?
    What color wire should it be?
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    Re: Tap off Cigarette Lighter for Amp Remote Wire?
    most cars the cigerette lighter stays on constantly after the car is shut off, so your amps would never shut off. tap into your red acc wire, or amp turn-on lead
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    It stays on in most trucks and older cars, but I know that on my car it it ignition switched.
    You want to tap the wire that goes to the center of the lighter. You should be able to tap the ignition wire for the HU though. If you search http://www.installdr.com/ for your car it will tell you what wires are what in the factory radio harness.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    Apr 2004
    Saudi Arabia
    30
    531
    Do Toyota's have the same style of radio like GM's do? Where the data-bus tells the radio to turn on with a signal? or is it just a 12 volt switched power wire like aftermarket H/u's have?
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,922
    no dont do it anyway at all.
    DaBurner's Avatar
    Jan 2006
    Long Island, NY
    147
    where is the Red ACC wire?
    Apr 2004
    Saudi Arabia
    30
    531
    my question is Toyota gimped in the head like GM?
    DaBurner's Avatar
    Jan 2006
    Long Island, NY
    147
    im not sure about that brendan, im pretty sure it does turn on with a signal tho
  9. #9
    iceteebone's Avatar
    Aug 2003
    Michigan
    33
    37,876
    Quote Originally Posted by DaBurner View Post
    well i forgot this is a stock radio so the wire probably won't be red. you'll have to check the diagram and see which wire is the acc. wire
  10. #10
    Apr 2004
    Saudi Arabia
    30
    531
    on install doctor is says a grey wire is the switched 12 volt on a 1999 corolla, thats all they had, they don't have a 2007.
  11. #11
    Apr 2004
    Saudi Arabia
    30
    531
    If it turns on with a signal your SOL, you will have to find a switched source somewhere else, or tap into a line and use a relay.
  12. #12
    iceteebone's Avatar
    Aug 2003
    Michigan
    33
    37,876
    if worse comes to worse, run a wire from your battery and wire in a kill switch
  13. #13
    Apr 2004
    Saudi Arabia
    30
    531
    You were saying that you had installed a new headunit, and your uncle made you remove it. Did the headunit work with a switched 12 volt?
    Also, take a look at this: http://www.installdr.com/InstallDocs...PDF/869001.pdf
    Tell me if your wiring harness on your 07' looks like the 1999 harness, I doubt it, but take a look.
  14. #14
    DaBurner's Avatar
    Jan 2006
    Long Island, NY
    147
    it does look pretty much the same, cant really tell tho, i dont know what im gonna do...
  15. #15
    killahbean's Avatar
    killahbean is offline AzN Sensation
    Feb 2004
    Houston, TX
    2,099
    omg....If your cig lighter operates with the key in the off position then dont use it but if the cig lighter doesnt operate in off position and only operates in the on positon, by all means tap into it.......its a simple test to find out
    If not then u can find out which wire is the accessory wire on the radio.....
    References.....
    Nick31 NikosBuddy Trancer Destruction Bumping150s ax600 IceTeeBone HOAX_1 Thunder9500 KngofThePkngLot LuckyT pimpedout97x wanginloud1 XDAVIEEXX Vetkilr Army-Killa Vitveet Record Holder07 iamamp3pimp Jared530 ShallowFu Stuckinok Ugs92 dleccord pwnt by pat jr2320 David706 tommyk90 UMGixxer tweet02 CJW BassAddictJ ace_800 ownage9
    ICIXSound - jochexum SVTF vehemental
    Do Not deal with LunchBocks And BoostdFoci
