Results 1 to 4 of 4
Reload Thread: terminal help
    xjmadness's Avatar
    xjmadness is offline The beauty of green
    Dec 2002
    ATL
    1,708
    terminal help
    ok im planning a box for 2 dual 2 ohm VC subs. i want to get a 2 ohm load so
    i would only need 1 terminal going out of the box to the amp correct??
    o and this may sound stupid but i do use speaker wires to connect subs to terminal inside the box rite?
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    If the subs are gonna share chamber space you should have it easy..
    One terminal cup (only one set of wires going in if you wire the subs together).. Speaker wire inside box from cup to speakers..
    You will have to wire each sub parallel, and put them in series with eachother.. parallel on one sub drops that sub to 1 ohm, seriesed 1 ohms gives you 2 ohm..
    You will have + on one sub, - on the other I believe.. sub 1 is + to +, - to - (both subs look the same that way, parallel on the voice coils), then from sub 1 + to sub 2 -, sub 1 - to sub 2 + (series the subs together).. sub 1 gets + from amp, sub 2 gets - from amp..
    If this is wrong, SOMEONE TELL ME (AND HIM) BEFORE HE BLOWS SOMETHING UP
    This means, don't do the wiring like I suggested until someone confirms this (make sure you know they are worth listening to, there are some here that are idiots and you shouldn't listen to them at all ... ThunderTunes for example...)
    Hope that helps (and is right)
    (1) Alpine CDA 7892 HU ($214)
    (2) 12" Pioneer Premier 1241DVCs in sealed MDF box (gonna glass them eventually) ($69 each)
    ->removing.. ->(2) 10" Pioneer Premier 1041DVC's in sealed MDF box (gonna glass them eventually) ($59 each)
    (2) Lanzar Vibe248 1200 watt 2 chnl amps ($119 each)
    It's bump'n GOOD!
    You can lead a horse to water but you can't make a moron understand...
    xjmadness's Avatar
    Dec 2002
    ATL
    1,708
    well im putting them in one box but im using a brace to separate the chambers...so what then?
    Savant's Avatar
    Dec 2002
    48
    1,347
    if the brace is 'solid', you would have 2 chambers.. if it's hollow and is just for stability, go as above..
    If the brace is a wall, you can still run the wires from one sub to the other through it .. either cut a hole in it (small enough for the wires, if you need it sealed use silicone or something) or put a terminal cup in it.. you have 2 wires from sub 1 to sub 2, just remember to reverse them on the other side.. You would also probably need 2 cups outside, one on each side of the brace (or holes.. )... you would only need the 1 wire from the amp still, just have the + going to one cup, the - to the other..
    Hope that helps..
    It's bump'n GOOD!
