+ Reply to Thread
Page 19 of 20 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 271 to 285 of 293
Reload Thread: >>>Engine whine and ground loop fixes... take two
  1. #271
    LordX's Avatar
    LordX is offline Member
    Aug 2009
    Syracuse, NY
    31
    4 Post(s)
    Re: >>>Engine whine and ground loop fixes... take two
    Hey guys - just read through this thread after getting my system installed in a new car.
    Had it done by a shop.
    Head Unit: Alpine 7897 - old school unit - but it rocks.
    The shop definitely ran the power and grounds on different sides of the car (saw it myself when I showed up half way through the install).
    I have 2 batteries (1 stock and 1 audio) - wired in parallel because my old isolator will not work in this 2012 Avalon.
    Noticed the engine whine right away.
    The Alpine 7897 has the rca outputs that 'dangle' out of the back of the unit. Is the ground trick still applicable?
    I saw a pic in the beginning part of the thread that looked like it.
    Is this trick something to even try with an Alpine HU?
  2. #272
    JohnKimble's Avatar
    JohnKimble is offline Junior Member
    Oct 2013
    California
    29
    15 Post(s)
    Disregard. Ground loop was solved by running a new and larger ground from my head unit, to the body of the car. Sanded the paint away, self tapping screw and lock washers made for a solid grounding point. No more alternator whine!
  3. #273
    bigBASSdevin's Avatar
    bigBASSdevin is offline Junior Member
    Dec 2013
    phx az
    how the f*** do i post a new post to the forum? yes i am a newbie and cant figure it out for the life of me...do i need to pay?
  4. #274
    Selvos's Avatar
    Selvos is offline Junior Member
    Jan 2014
    Europa
    14
    2 Post(s)
    Ok I have a Pioneer x1500.
    I fixed the alternator whine by wrapping the RCAs. Does this also apply to the sub rcas? My subs do not work now. They have their own ground running with the cables Which I attached to the main ground wire on the wiring harness.
    THanks
  5. #275
    anger's Avatar
    anger is offline Senior VIP Member
    Aug 2012
    Oxnard, CA
    311
    7 Post(s)
    77 Post(s)
    Just want to confirm that running the power and signal too close together CAN cause this...to anyone thinking it's BS.
    I recently bought a truck with a sloppy install, so I decided to clean it up and when I finished I had the dreaded 'whine'..and didn't introduce any new equipment to the system. So I pulled up the carpet again and separated the signal and power wire (I ran them right next to each other for a good 3ft) and problem solved.
    I've also had luck grounding the RCA's to the head unit on another install.
    Thanks CarAudio.com community for all the help and info!
  6. #276
    Trasero05's Avatar
    Trasero05 is offline Member
    Dec 2013
    Phoenix
    57
    12 Post(s)
    Very thankful I found thisss it really help me
  7. #277
    sbsyncro's Avatar
    sbsyncro is offline Junior Member
    Jun 2014
    SoCal
    Hey y'all. Found this thread via Google search and figured I'd post up my situation and see if anyone has helpful advice.
    Problem Description: Soft background hiss/whine when engine is running that is noticeably louder than the normal amp hiss (which goes away when I turn the gain down). It is not a high-pitched whine that goes up and down as I rev the engine. More like the sound of a low-rpm motor running at the same RPM regardless of the engine RPM. There is a slight variation with engine speed but its not the screeching whine I've heard before in other cars.
    Install notes: Pioneer AVH-5600BHS HU, Infinity 474a amp, Infinity reference speakers front and rear. Knukoncepts Basik RCA cables. Klarity 14 gauge speaker wires. 4 gauge battery lead, 4 gauge ground to clean, scraped attachment to body. RCA cables run up opposite site of car from power.
    What I've Tried: Unplugging RCA from the amp stops the problem. So does puling the RCAs from the HU. Interestingly, only 3 of the four RCA cables (and therefore speakers) is exhibiting the noise. I can pull the front 2 channels and one of the rears, have pure sound coming from the remaining speaker without background noise. As I plug in the remaining leads, they will each have the background noise.
    No effect/improvement: Isolating the amp from its mount. Swapping RCAs to different channels. Running separate RCAs directly between HU and amp
    Made problem worse: Grounding the amp body. Grounding body of HU with separate lead. Wrapping wire around RCAs on back of HU and grounding to the HU body (per the first post on this thread). Each of these made the ticking noise noticeably worse.
    Not sure what to do next. What is puzzling me is that one of the channels is NOT having the noise, yet is wired exactly like everything else. FWIW, that channel doesn't exhibit the noise regardless of which cable I use, so the problem follows that signal channel, not the RCA...
    Any suggestions short of using a pair of GLIs? (by the way is there such a thing as a "good quality" (or better quality) GLI, or are they all bad in terms of attenuating signal and flattening dynamic response?
  8. #278
    CJRananto's Avatar
    CJRananto is offline Junior Member
    Aug 2015
    Hickory, NC
    2 Post(s)
    I have the same issue. When I have just one pair of RCAs plugged in, there is no noise. But as soon as I plug in the other set, there is noise. Doesn't matter which goes first. Seriously puzzled. Did you ever resolve this?
  9. #279
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2847 Post(s)
    Quote Originally Posted by CJRananto View Post
    you have a piece of equipment inducing noise into your system due to a bad ground, faulty internals, etc
  10. #280
    CJRananto's Avatar
    Aug 2015
    Hickory, NC
    2 Post(s)
    Amps are grounded separately on sanded down metal (floor under seat bolt front, floor under seat bolt rear). HU separate ground wire to firewall. Was told that I should ground my amps to battery instead of floor due to way new cars are made. Suggestions. I have a 2009 Sienna. BTW. Thanks mitchell0715.
  11. #281
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    5,308
    50 Post(s)
    2847 Post(s)
    I wouldn't ground to the battery unless you know your car has a body with terrible resistance, and even in that case I'd ground to the engine or frame then run a ground from your frame up front to the battery. If your car has no frame id ground it to the engine then upgrade your engine ground to battery.
    Start a new thread so we can assist you better, include what amps, headunit, etc you're including. keep it concise but provide as much info as possible and you'll get my help as well as a few others.
    the short story for what i think your problem is, is that there's a difference in ground impedence between your amps and the excess difference is being transferred through your RCAs when the second piece of equipment is plugged in
  12. #282
    CJRananto's Avatar
    Aug 2015
    Hickory, NC
    2 Post(s)
    Thanks. Will do.
  13. #283
    Bigokie's Avatar
    Bigokie is offline Junior Member
    Aug 2015
    Oklahoma
    22
    1 Post(s)
    7 Post(s)
    Another Pioneer sucker.....installed new amp...WHINE.....with the help of adulbrich we narrowed it down to a few things. Tried in order of "how easy" and it was probably the 4th thing on my list.....GROUND THE RCA PLUGS!!
    A huge thx to adulbrich, I have been tearin his inbox up and he doesn't hesitate to help, as well as others.
    Awesome forum.....yall have been nothing but help!! I appreciate all the replies in other posts.
    Okie
  14. #284
    nvturbo's Avatar
    nvturbo is offline Senior VIP Member
    Nov 2012
    North Carolina
    158
    28 Post(s)
    After re-installing my setup, I noticed alternator whine at low volume. Checked the grounds on both amps, making sure they were as short as possible. I'm using Streetwires Musica100 and 200 RCA cables along with OFC Streetwires power & ground wires BTW.
    Come to find out, it was the MTX 250x amp. Swapped it back to the Alpine 3547 and noise was gone. In some cases, it's a component causing the noise, other than a headunit.
    1997 Honda Del Sol Si
    * ///Alpine CDA-9851 CD player
    * Audio Control 2XS crossover
    * Soundstream Reference 500s
    * Precision Power PPI-2030M
    Front -- Morel Maximo 6 6.5" components
    Rear -- Pioneer TS-A1686R 6.5" speakers
    Sub -- American Bass XD1044 (pair)
  15. #285
    Jard's Avatar
    Jard is offline Junior Member
    Feb 2016
    BC, Canada
    So glad I found this sticky. My system has been running fine for 6+ years in two separate vehicles, then suddenly it acquired this problem last week. I had no idea what it was, but started taking notes on the causes of it. Made this account and was about to write up a huge post describing the problem.... but now theres no need to. Will try some of the fixes until i solve the issue. One thing to note is that I had a new battery installed (by someone else) last week, about the same time the problem arose. Could this have anything to do with it? The high pitched whirr is only present in the front speakers which are driven by their own amp. Rear speakers are driven by the head unit, and have no whirr.
    Edit: Just to clarify, when it says to ground the RCAs to the head unit, does that imply that the head unit should in turn be grounded to the frame of the car?
+ Reply to Thread
