+ Reply to Thread
Page 16 of 18 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 226 to 240 of 269
Reload Thread: >>>Engine whine and ground loop fixes... take two
  1. #226
    Librac23's Avatar
    Librac23 is offline Junior Member
    Jun 2010
    Mason,WI
    Re: >>>Engine whine and ground loop fixes... take two
    Greetings,
    I've got the same thing going here guys/gals, I've got a Pioneer Premier DEH-P500UB H/U my sweet girl got it for me on my birthday, its a sweet deck.
    Had it for almost 2 yrs now, warranty is almost up, and one day, it started whining after an install..Like most of you out there, I grounded and regrounded everything, removed paint, drilled new holes, even up graded Cables..Nothing seemed to work. hell I even isoliated the whole H/U...Now i more or less stumbled a crossed this thread, and I have to hand it to you guys, I freaking worked. I had every kind of buzz, whine, thump, pop, you could think of. Now Its as quiet as a sleeping baby.
    Took some remote wire I had around, and grounded my RCAs, and I grounded the deck straight to the batt. Perfecto!!!!!
    So, Thanks, you saved me a buttload of frustration,time and money.
  2. #227
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,245
    Glad to see another happy customer.
    '98 Jeep Grand Cherokee
    Source: Pioneer 880 PRS *Active
    Tweeters: 1" CDT TW-25
    Midrange: 6.5" CDT CL-65
    Sub: 15" SSA Icon
    Box: 4.0 @ 32hz
    Amp: Soundstream Tarantula 2kW
    Feedback thread
  3. #228
    bradfordpoole's Avatar
    bradfordpoole is offline Senior VIP Member
    Nov 2009
    Statesboro, GA
    485
    Ill be redoing this today on my D3. Ill post results.
    Bought from: Toone , funandgames , Jason19 , mrteacha
    Sold to:
    Setup coming soon
  4. #229
    Nov 2009
    Statesboro, GA
    485
    Grounded my RCA's (front and rear outputs) and it eliminated the whine a little bit but its still there. HELP!
    Sold to:
    Setup coming soon
  5. #230
    dudestone's Avatar
    dudestone is offline Junior Member
    Jun 2010
    portugal
    i will try that fix today on my deh 3900MP.. i hope that works
    but anyone knows where is the fuse to replace it?
  6. #231
    soderdna's Avatar
    soderdna is offline Junior Member
    Feb 2011
    Strathroy
    28
    would grounding out the rca's work on a JVC deck as well?
  7. #232
    ricktcole's Avatar
    ricktcole is offline Member
    Jan 2010
    Elizabeyh City,NC
    65
    I don't think that is just Pioneer HU's that have this problem. I have a Kenwood HU and mine has started to have engine whine. I'm going to try this tomorrow and see if it works. Hope it does I've tried all of the other grounds. I post after it's done
  8. #233
    soderdna's Avatar
    Feb 2011
    Strathroy
    28
    any luck with the RCA's ricktcole?
  9. #234
    soderdna's Avatar
    Feb 2011
    Strathroy
    28
    ok so I tried this fix on my deck but ran into a problem. My RCA's arnt hard mounted into the deck, they have a length of cord coming out of the back of the deck. Is there away to ground these or am I S.O.L.?
  10. #235
    srch4aresn's Avatar
    srch4aresn is offline Member
    May 2009
    Palm Beach
    93
    just wanted to drop in and say thanks for the pointers listed on here. long with the big3 i just completed, i also upgraded my HU's ground and also grounded the RCAs. absolutely noticable.
    the only thing i have yet to try is running power/rcas on different sides of the car. like the op said, i also have heard like half and half... some say don't worry about it, some people say absolutely do this.
    95 caprice on 24s
    31k miles
    bought from: BlackFx4inTN
  11. #236
    drjoeshmoe's Avatar
    drjoeshmoe is offline Junior Member
    Apr 2008
    bakersfield, ca
    Can someone email me back on this?
    I purchased a DEH-23UB for my wifes 02 toyota highlander, she has a factory amp somewhere in there so i have to get a wireing harness to accomadate the one plug harness and it has only RCA plugs to go into the pre outs of my HU.
    I have the terrible whine and static.
    I tryed the wrapping of the RCA's which did not work.
    My questions are: Is this suppost to work when you are also using those RCA pre outs?
    and I realize by looking at other photos I may have done it wrong.
    I started with the little screw directly by the RCA plugs, wraped the two L and R inputs and back to the same screw... I did not send the wire off of the RCA plate (mount)... do I simply need to send this wire away form the RCA plugs or should this have worked?
    Someone please let me know,
    drjoeshmoe@yahoo.com
  12. #237
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    36
    6,304
    30
    20 Post(s)
    Quote Originally Posted by jmanpc View Post
    Alrighty guys, since we no longer have access to the other ground loop fix thread, thanks to someone (you know who you are), I'm making a new thread about it.
    Ground loops and engine whine cause common problems such as a high-pitched whine that varies with engine RPM's, various thumps while changing tracks, turn on/off thumps, etc.
    There are various protective measures to take in order to decrease the likelihood of experiencing engine whine and ground loops.
    • Shielded RCA's
      A good pair of shielded RCA's may be the easiest way to avoid engine noise. Don't use patch cables or other el-cheap-o RCA's that are unshielded. I'm not saying you need to invest a small fortune in RCA cables, just make sure they are shielded.
    • Proper head unit ground
      This is perhaps the most common source of engine noise. Many times factory head unit grounds are poor. Relocating the ground wire or adding to the existing one will help reduce or eliminate ground loops.
    • Proper amplifier ground
      If none of the above have worked, check the ground for the amplifier. Make sure it is grounded to the frame, battery, or other substantial metal surface. Make sure the metal is good 'ol fashioned detroit iron. Many cars use metallic alloys or composites that aren't very conductive. Avoid those at all costs.
    • Wire routing
      Some claim this next fix is BS, and others swear by their grave that it works. But run your RCA's and power wires at least 18" apart. I route my RCA's on one side of the car, and power on the other. Couldn't hurt.
    • Grounding the RCA's on the head unit
      Many have had problems with Pioneer head units because of a poor internal RCA ground. To remedy this, simply wrap wire around the RCA's and screw the wire down to the head unit's chassis like so:
      Thanks to Ultimate157 for the image.
      To view his thread on this subject, click here.
    Please note: While ground loop isolators are tempting to use as a quick fix, I generally don't advise people to use them because they simply cover up the problem instead of solving it. Only use ground loop isolators as a final resort is none of the above fixes work.
    Enjoy
    does this RCA remedy work with all pioneer decks?
  13. #238
    subzero's Avatar
    Sep 2008
    Phoenix, AZ
    36
    6,304
    30
    20 Post(s)
    Quote Originally Posted by subzero View Post
    Well apparently it worked for me!!!
  14. #239
    AlterEgo99's Avatar
    AlterEgo99 is offline Streaming consciousness
    May 2009
    Domie Homie
    12,623
    19 Post(s)
    Adding a second Kinetik batt and grounding the shit out of it (grounding to frame AND block) did it for me...didn't have too much whine, but when I added the second battery, voila! Good, solid grounding of the electrical system is key IMHO.
    Eddie Izzard: Squirrels always eat nuts with two hands, always two hands, "arararar", and occasionally, they stop and go...oh, uh, ah, as if they're going, "Did I leave the gas on? No! No, I'm a fucking squirrel!"
  15. #240
    Mar 2006
    Worcester, ma
    7,245
    5 years later and that radio is still kicking around, with the same exact wire around the RCAs. Currently installed and running in one of my vehicles.
    Sub: 15" SSA Icon
    Box: 4.0 @ 32hz
    Feedback thread
+ Reply to Thread
