+ Reply to Thread
Page 14 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 196 to 210 of 293
Reload Thread: >>>Engine whine and ground loop fixes... take two
  1. #196
    AlterEgo99's Avatar
    AlterEgo99 is offline Streaming consciousness
    May 2009
    Domie Homie
    12,536
    437 Post(s)
    Re: >>>Engine whine and ground loop fixes... take two
    Quote Originally Posted by jkbeaumont1 View Post
    Did this work on your Kenwood? Update please!
    Bump...I'm curious if anyone has attempted grounding the RCA's as suggested in this thread on a non-Panasonic HU? Anyone????
    Eddie Izzard: Squirrels always eat nuts with two hands, always two hands, "arararar", and occasionally, they stop and go...oh, uh, ah, as if they're going, "Did I leave the gas on? No! No, I'm a fucking squirrel!"
  2. #197
    The HACKER's Avatar
    The HACKER is offline custom chaos
    Oct 2009
    Robstown, Texas
    718
    This thread has convinced me pioneer *****...
  3. #198
    JuicyJeff's Avatar
    JuicyJeff is offline Juicy
    Aug 2009
    Near Cleveland, Oh
    1,648
    2 Post(s)
    NAIICE. I been having some trouble too. Just moved my grounds and to bare chassis so its not those. I may try and reground my headunit to a bolt I found out today that It is either the rcas or the headunit at this point. As there is no alternator noise until the rcas are connected into my speaker amp. And as for grounding the rcas, i haven't heard of anyone with problems with a clarion headunit, and my last headunit (Sony) Also had the same problem with the whine
    2012 6 speed Mazda 3 Skyactiv
    Hids
    Working on the rest!
  4. #199
    JuicyJeff's Avatar
    Aug 2009
    Near Cleveland, Oh
    1,648
    2 Post(s)
    Quote Originally Posted by hellabent View Post
    Dont know if this is a ground loop or not but... I have a pioneer h/u, 2 punch 800s, and a cap. I recently had to change my fuse and fuse holder under the hood due to it melting together. So I replaced it and now when I turn the system on and off it has a loud popping and i can hear a high pitched noise. Then once I crank the engine it has a very loud engine noise. I have checked all grounds and all are bolted to thick metal. This only happens when i have the rcas from the head unit plugged into the amps. I can take an ipod and plug it into the amp for mids and highs and it works fine. Every thing was working fine untill i changed the Fuse holder......Any help would be great as ive been going around and around with this problem.
    The amp has a quiet shutoff function built into the amp. Which means that it holds some energy or something in it so that when it shuts down it doesn't make that pop noise and what i would think is it releasing all the leftover power at once. What you may have done is fried this when you had your meltdown or whatever. As of now, there is no way to fix this. You can A) Get the amp repaired B) Buy a new one or C) Live with it.
    Hids
  5. #200
    JDMB20TDA's Avatar
    JDMB20TDA is offline Junior Member
    Sep 2009
    chicago
    25
    dehp7500mp Fixed!
    awesome.
  6. #201
    M4ST3R_OWNER's Avatar
    M4ST3R_OWNER is offline Junior Member
    Nov 2009
    Mississippi
    i have pioneer 4900. i tried everything. moved rca on opisite side of power wire. moved amp 20 times. moved ground wire to amp to chas under car. tried bolting ground wire to frame and running to headunit.
    nothing worked. the sound just drove me crazy. when your idle its at its loudest. i just couldnt take it anymore. i found this site, and i was like ill give it a try. and it works!!! omg thanks so much. i couldnt beleave pioneer havent fixed this. this will be my last pioneer...sad, i really like the radio. wish they would fix it, or do recalls and fix it for free. but thanks so much.
    heres what i did, hope it helps someone see.
  7. #202
    AlterEgo99's Avatar
    May 2009
    Domie Homie
    12,536
    437 Post(s)
    Wow, some big *** pics there!
  8. #203
    Nov 2009
    Mississippi
    yea i took them with my iphone hahah. i didnt know they were so big.
    www.youtube.com/m4st3rowner
  9. #204
    xguntherc's Avatar
    xguntherc is offline I Click Home Too Much
    Dec 2008
    Las Vegas
    150
    Very Informational thread.. I currently just barely installed a 4 channel amp running all 4 doors, and newly Just started having this whine problem.
    Today while idle it was blaring, and hitting gas even when in park it gets louder, but turning volume up even when playing nothing doesnt increase it.
    I tried turning off my HU and the whine stopped. This makes me think its either the 4 channel amps ground, the HU needs a better whine (but never noticed it before and its the same HU from when I only amped the sub) or its the RCA's bit I got nice ones. Any suggestions? I think i'll try tapping into and adding a better ground for the HU, and rechecking the amps ground
    - JVC KD-AVX44 3.5" LCD HU -
    - Patriot Xporter 16GB Flash Drive -
    - iPod Touch 3rd Gen 32GB or Google Nexus One (16GB) -
    - Polk Audio PA600.1 | JL Audio 300/4 Slasher 4 Channel -
    - JL Audio 12w6 v1 (Ported) | Alpine Type "S" 6.5 x 4 Doors -
    - Rockford Fosgate 4 AWG, RF RFIT 16' Woven RCA's -
    - Monster 4 AWG, JL XB-BLUAIC4-18ft. Interconnect & BIG 3 -
    - Code Alarm Theft System + Extra Sirens Soon -
    Thou Shalt Not Steal
  10. #205
    Loodachris's Avatar
    Loodachris is offline Junior Member
    Nov 2009
    Tacoma Wa
    New to the forums and I too am having a buzzing sound after I installed my Alpine amp. I have moved grounds and still no change. I bought a couple ground loop isolators and it did cut the buzzing sound in half but now I lost bass in that channel. I am not running a sub so the outcome of this *****. I have a JVC KW-AVX810 head unit and the new amp is an Alpine MRP-F300 any ideas
  11. #206
    AlterEgo99's Avatar
    May 2009
    Domie Homie
    12,536
    437 Post(s)
    Quote Originally Posted by xguntherc View Post
    There are actually some very good links out on the net that if you follow step by step you can isolate where the issue is coming from. Otherwise, it can be a rather frustrating trial and error hunt.
  12. #207
    amartin_72's Avatar
    amartin_72 is offline Banned
    Nov 2005
    Madison , WI
    1,777
    dont unplug rcas from amps when they are playing or dont reconnect them when there playing
    I let my inside (positive) pin from the rca touch the ground part of the rca input on my eq and now its whining probably blew a ground fuse somewhere
  13. #208
    Blue_C1500's Avatar
    Blue_C1500 is offline Member
    Jul 2009
    Louisiana
    56
    Quote Originally Posted by Chaos1187 View Post
    Agreed, if you notice the first post in this thread is from 2006 and we are a week away from 2010 and they still have the same problem. I wonder why there's 3 threads or more a week about RD having a batch of bad amps but this has been going on for 4 years and noone is biitching about this.
    H.U. - Pioneer DEH-P7000BT (JUNK!!!)
    Highs - 2X Fosgate 5.25 comps, 1X Boston Acoustics 4X6s, and 1X Boston Acoustics 3.5s
    High Amp - Sundown Sax-125.2
    Subs - 4X Sundown Nightshade 15s
    Sub Amps - 4X Sundown SAZ-3500Ds
    Electrical - DC Power 320 alt, 2X D3400s, and 4X D2700s
    SPL - 159.4db @ 47Hz
  14. #209
    SYLrules's Avatar
    SYLrules is offline PERMANENT VACATION
    Feb 2008
    EAST TEXAS
    45
    About a year ago, I bought a pioneer h/u and decided to not ground the RCAs, and until a few days ago, everything was fine. somehow, i got some power surge or something that fried my RCA cables. when it first happened, there was no sound so I figured some wire came loose. i get out and check everything and no wires were crossed and everything was still plugged in. i crank up my car again and im getting sound, but theres some incredible noise through the subs and door spkrs. i looked at the ends of the RCAs as the ones going to my sub amp are transparent and they look really ****ed up.
    i wonder if this RCA grounding trick would have prevented my cables from getting fried. guess once i replace them and do the ground, ill find out. i dont think my h/u is ****ed but i wish it were so i could get a new one from the warranty and sell it. i need something that doesn't have a seizure while trying to play CDs with microscopic scratches.
    Last edited by SYLrules; 02-13-2010 at 12:49 AM. Reason: add photos, fix spelling errors
  15. #210
    SYLrules's Avatar
    Feb 2008
    EAST TEXAS
    45
    got my new RCAs in today. first i plugged em in without doing the grounding trick. still the same insane noise as with the other RCAs. did the grounding trick and tried it again. ZERO noise! woohoo! maybe my other RCAs werent shot but oh well, ive got better ones in there now.
+ Reply to Thread
