Results 1 to 4 of 4
Reload Thread: 97 Escort - Need tips to reduce rattle
    97EscortBoom's Avatar
    97EscortBoom is offline Junior Member
    Feb 2002
    Front Royal, Virginia
    33
    I have a 97 Ford Escort with a spoiler that makes a ton of noise and also a bumper that does the same. I can use any and as many tips as anyone has to reduce this noise. Also, will dynamatting my trunk make the boom sound louder outside also?
    email me amspenik@hotmail.com or reply here
    Desperately Seeking less Outside Noise and More BOOM!!
    CCRoadshop Tech's Avatar
    CCRoadshop Tech is offline Junior Member
    Feb 2002
    FL
    34
    Dynamat
    The use of dynamat and other sound deadening material will help in the reduction of rattle in your vehicle. It all depends on how much of it you will use, and if it is in the right spots. I would recommend the use of dynanmat extreme. It dampens extremely well. And in the hard to reach areas use the spray. Using this will keep the sound inside the vehicle, and not outside the car.
    Unregistered's Avatar
    Unregistered Guest
    I agree with what he said and also try to tighten everything down as tight as you can to help stop the rattles. Remember that the more you rattle the more bass gets taken away so good luck.
    EPanther99's Avatar
    EPanther99 is offline Senior VIP Member
    Feb 2002
    Elizabethtown KY
    32
    306
    another product i saw this weekend at the car show works really good for the license plate, it was the dynamat license plate kit, but more or less all it has is a piece of extreme for the back of your plate and then a dynamte frame for the plate, but it was only 15 bucks so it was worth it to stop the plate from vibrating and rattling.
    HU: Pioneer Premier P-720
    Front: JVC 2 way 6.5" component system
    Rear: Kenwood KFC-1687
    Subs: (2) 2002 Kicker 15" L7's
    Amps: (2) Infinity Beta Digital 300's
    (2) 1 farad Stinger Power Caps
    (2) 1 farad Monster Cable Monster Caps
  1. About to start construction, NEED tips!
    By xpl0it in forum Enclosure Design & Construction Help
    Last Post: 06-24-2006, 07:59 PM
  2. Car shakes like hell! Need help to reduce vibration!!
    By adrian868 in forum Enclosure Design & Construction Help
    Last Post: 04-19-2006, 03:45 PM
  3. need tips on first box build
    By Twistid in forum Enclosure Design & Construction Help
    Last Post: 02-14-2006, 12:07 AM
  4. SPL comps coming soon! need tips
    By Aphix in forum General Discussion
    Last Post: 02-01-2006, 08:44 PM
  5. Need Tips and Help on How to Build a Fiberglass Box
    By Nyris221 in forum Enclosure Design & Construction Help
    Last Post: 01-10-2005, 09:00 PM
