Results 1 to 3 of 3
Reload Thread: question about amp with external fuse
    treefitty's Avatar
    treefitty is offline Junior Member
    Dec 2002
    in a cave
    Icon32 question about amp with external fuse
    I have a Hifonics Z8000 (5 channel), but the amp does not have a fuse on it. Hifonics recommends a 50 amp external fuse. This is my first amp with an external fuse as all my previous amps have had fuses on them.
    (1): Is the external fuse the same thing as the fuse on the power wire at the battery or should there be a seperate external fuse near the amp?
    (2): This question applies if the answer to the first question is that the fuse at the battery is also the external fuse for the amp.
    I have an amp kit that came with a 60 amp fuse. Should I swap this out for a 50 amp fuse or is the 60 amp OK?
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    the answer is yes....and as for the 50 or 60 fuse....probably wouldnt matter to much...but to be on the safe side i'd go w/ the 50
    treefitty's Avatar
    Dec 2002
    in a cave
    thanks. i'll pick up a 50 amp fuse soon.
