Need help on wiring set up
Do you think that this sounds correct?
I am looking to run 4 kicker 15's and I have to get it so that the amp will see 1ohm with these. Would getting 4 - 8 ohm 15's? I am asking because person has 2 - 4 ohms and also 2 - 8 ohms and wanted to see which would go best since i would have to purchase 2 more. The amp that I will be using is a MA audio hk802sx 2 channel amp
1 x 4400 Watts RMS @ 1 Ohm Bridged
2 x 2200 Watts RMS @ 0.5 Ohm Stereo
thanks for input as i am waiting on response before buying the set up
Re: Need help on wiring set up
yes 4-8ohm subs will be 1ohm at the amp if the subs are DVC(dual voice coil) subs
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
