Results 1 to 7 of 7
Reload Thread: Head Unit Clipping....would using a...
    aea151's Avatar
    aea151 is offline Junior Member
    Dec 2002
    here
    23
    I have a situation where I am using my factory deck to run a mmats D100HC to a Mmats Juggernaut. I am getting a good signal however, at higher volumes I am experiencing clipping and cut-off in my factory deck.
    Instead of using a Hi-Level to Lo-level converter, I opted to use a RCA speaker wire and cut it to run in-line with my front two channes.
    My questions are:
    1) Is the deck reacting as a bridged load causing the deak to go into protection and cut-off?
    2) Am I just using too small guage wire?
    3) Should a capacitor be used in-line with each channel? If so, should it be in parallel with the (+) and (-) channel?
    Keep in mind the wiring is correct as for as polarity and It has been isolated to the deck and not the amp.
    Thanks in advance guys!
    aea151's Avatar
    Dec 2002
    here
    23
    w
    Good question:
    But the only thing is the clipping occurs at moderate volumes at times also...as if the head unit is heating up (which may be the case). But being that I have played the head unit at very high volume (excluding the rca's) without the cut-off and clipping, it has to be related to me putting the RCA speaker wire on to the deck.
    I thought about putting a 47uF cap on the speakers, but that would only serve as a filter(depending on how I configure it).
    I guess my concearn is what can I use to take some of the heat off the front channels of the factory deck?
    aea151's Avatar
    Dec 2002
    here
    23
    n
    There is a built in fan on the factory Delco deck. The clipping occurs during about 20 min of play at moderate volume and about. I still have to hook up my cap (1 Farad) to the amp, but that wouldnt be the problem with the deck (i dont suspect).
    Another question:
    Is the fact that I have two channels running to a mono (bridged) mmats amp into a parallel ran, dvc, sub have anything to do with the drain on the deck?
    aea151's Avatar
    Dec 2002
    here
    23
    I agree
    I agree,
    Well, I might have to try to get a in-line converter. I saw one that I like on:
    www.partsexpress.com
    They have one that does NOT have a dial (potential meter) on it....lawd knows I dont need any more sound delivered to that amp....I think my ears started bleeding last time I got in the truck....
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,238
    8 Post(s)
    Re: Head Unit Clipping....would using a...
    I don't understand. You running speaker level inputs into your amp without a LLC? That'd seriously overload the input to most amps. Clipping? Hell ya.
    Amp inputs are ground referenced, so a bridged speaker level needs isolation. A cap could be placed in either leg, but I'd do it on the neg side.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
    aea151's Avatar
    Dec 2002
    here
    23
    u
    First off thanks for the help, Im learning a lot. The connection I have is such:
    From the HU, I have taken a speaker wire from Radio Shack. This particular speaker wire has RCA headers instead of just the normal clipped speaker wire. I cut it so as to have two rca type headers on one side and speaker wire on the other. From there I have tied (in-line) the speaker wire side of both them to the front left and front right channels.
    I had two female-to-female couplers, in which on one side (HU side) I have the radio shack RCA type connection. The other side (AMP side) is a actual triple shielded 17' RCA cable that was previously ran to the amp.
    I guess what I need to be asking is what does a Hi-level to low level converter have in it that makes it function differently from the connection that I currently have?????
    aea151's Avatar
    Dec 2002
    here
    23
    t
    bump
