Results 1 to 8 of 8
Reload Thread: 2006 Jetta VSS Wire
    scotsman's Avatar
    scotsman is offline CarAudio.com Elite
    May 2006
    SugarLand, TX
    567
    2006 Jetta VSS Wire
    I am installing an Eclipse AVN6600 into my 2006 Jetta and it says that I need to splice into the vehicle speed pulse signal. Does anyone know where this is located on the new Jettas?
    scotsman's Avatar
    May 2006
    SugarLand, TX
    567
    Re: 2006 Jetta VSS Wire
    anyone?
    scotsman's Avatar
    May 2006
    SugarLand, TX
    567
    alright I have accomplished that problem, but I just turned the unit on to test it and it works great except when I turn the car off and take out my key the radio and screen still stay on.
    mikeyboc's Avatar
    mikeyboc is offline CarAudio.com Veteran
    Oct 2005
    Sugar Land, TX
    33
    2,083
    Quote Originally Posted by scotsman View Post
    Does it turn off when you open the door?
    PatFitz9's Avatar
    PatFitz9 is offline CarAudio.com Veteran
    Sep 2005
    Chicago
    29
    3,787
    you have to turn the display off manually, because they are lame like that
    refs...
    twoohfour, PRIVATEpastry, hellomota, DBfan187, etznova, iamamp3pimp, btnhfan, XylerB, Digital B, Showrides, Thunder9500, Termlab, fawd06, PepsiFiend69, bholtmeier, Megalomaniac, bjfish11, j3bus2k3, probmxstyle, brigante, massiveaudiocw, JoeHemi57, BigRed98Ram, inapontiac, CFaber, VarsityBumper, 3.5Max6spd, Geezerpoop, phatcat600, Pimpdaddyq, XaznKewLguyX, ABSOLUTEAUDIO, lslugz, mgbcs, TeZ, mazdakid, Reson8, LaserRed38
    scotsman's Avatar
    May 2006
    SugarLand, TX
    567
    Quote Originally Posted by PatFitz9 View Post
    seriously? but what about your sound, does that stay on too?
    mikeyboc's Avatar
    Oct 2005
    Sugar Land, TX
    33
    2,083
    That's not right, mine stays on until you open the door and then it shuts off. Double check your wiring behind the unit to make sure you it is correct. If it is, just look for another power wire that is syn with the ignition.
    heyman421's Avatar
    heyman421 is offline Veteran Camel Master
    Jan 2006
    Akron, OH
    4,179
    alpines have 2 power wires, wire one directly to the unswitched power supply under the dash, and the other to a switched fuse
    and last i heard, 2005+ vw's need to have the factory radio installed somewhere in the car, or vagcom diagnostics (and therefore your warranty) don't work
