Results 1 to 2 of 2
Reload Thread: 91 prelude
    penguin's Avatar
    penguin is offline Junior Member
    Jan 2002
    surrey
    35
    23
    91 prelude
    ok..i gots a 91 prelude si....
    gots 2 rockford 10 he s .......they can each take 400 watts.in a dual ported box.
    1.)the seats fold down...so should i point the subs towards the front or back..
    2) what amp would you recomend to power them
    and 3) what is rms? ohms and how does this relate to what i need to buy...
    PLEASE HELP
    one by one the penguins steal my sanity
    "this next song goes out to everyone in a five block radius"
    fu-man-chu's Avatar
    fu-man-chu is offline Member
    Nov 2001
    129
    OK........
    Ok, first question are the subs the 4 ohm or 8 ohm modles, and also how much are you willing to spend on an amp?
    To answer your first question,..... the subs will preform better facing the back.
    To answer your second question,.....If u have the 4ohm models then you should look for an amp that dose 400-500 watts RMS in a 2ohm load. EXAMPLES: RF 500.1, 500 watts RMS @ 2ohm's. JL 500/1, 500 watts RMS @ 4-1.5 ohms. MTX T6500D 500 watts RMS @ 2ohms. These amps should work great if you have the 4ohm SVC's
    If you have the 8ohm models then you should look for an amp that dose 400-500 watts RMS @ a 4ohm load. EXAMPLES: RF power 500.2 500 watts RMS @ 4ohms. Alpine MVR-T757 400 watts RMS @ 4ohms. JL 500/1(same as above) These amps will work well if you have the 8ohm SVC's
    Third.....RMS is the ratting of continuos power an amp will put out. If you have the 4ohm SVC or 8ohm SVC subs you should wire the subs in parallel( + from the amp to + of both subs and - from amp to - of both subs)
    Hope i helped, good luck.
  1. engine swap for 92 prelude
    By rick22 in forum Car Interior/Exterior Enhancements
    Last Post: 07-14-2004, 01:18 PM
  2. 91 Honda Prelude
    By yomell in forum Speakers
    Last Post: 06-22-2004, 09:05 PM
  3. Speakers for Prelude 98
    By tritonstudio in forum Speakers
    Last Post: 09-04-2003, 10:48 PM
  4. Prelude
    By B&R Innovations in forum Car Interior/Exterior Enhancements
    Last Post: 05-14-2003, 05:04 AM
  5. 97 Prelude drivers - inside please
    By swingking03 in forum General Discussion
    Last Post: 02-26-2003, 09:12 AM
