Results 1 to 1 of 1
Reload Thread: Jensen CD player with jammed cd
    RidinSideways's Avatar
    RidinSideways is offline Junior Member
    Dec 2002
    Sequim, WA
    32
    Ok I bought my car used, it came with a jensen cd player, i dont know the model but im sure its low quality since it can barely play recorded disks... It jammed a cd after the power cable came loose and turned it off and on several times until i could put it back in place, now when i press eject it doesn't eject but instead says "CD Load" It wont play either, anybody know how to get the friggin CD out?
    added a little bit later...
    Ok this post should stay up because maybe u can learn from it. I fixed the problem by doing several things, im not sure which was the solo anidote...
    I turned on my car and deck, then unplugged the power source then replugged it
    Then I tried ejecting the disk... nothing
    Then I pressed next track several many times until it quit saying CD Load... pressed eject and presto!
    I tried pressing next track all day yesterday along with, play, mute pause... EVERYTHING, but im suspicious that the power source was the problem
