Results 1 to 13 of 13
Reload Thread: door and panel speakers
    perrydog's Avatar
    perrydog is offline Senior VIP Member
    Mar 2006
    g-ville
    333
    ok i have a quick question probly....is there sumthing i can buy to stop bass coming thru my panel and door speakers....i have my HU bass setting at -12 as far as it will go.....i hope someone can help....thanks
    project f-150's Avatar
    project f-150 is offline CarAudio.com Elite
    Feb 2006
    Tampa, Fl
    518
    Re: door and panel speakers
    yes you can buy capacitors at most car audio shops. or online try crutchfield
    http://www.crutchfield.com/S-5zHE4lp...roup.asp?g=761
    Feb 2006
    Tampa, Fl
    518
    but if you have your bass turned down that low you really shouldnt be getting much bass!!! you dont have your head units LOUD setting turned on or bass boost or something do you?
    dkmesa's Avatar
    dkmesa is offline CarAudio.com Veteran
    May 2006
    Atlanta
    2,104
    Those bass blockers outta do the trick
    perrydog's Avatar
    Mar 2006
    g-ville
    333
    whats the difference.....i mean i see different hz rating but what one do i need....sorry dumb when it come to that
    perrydog's Avatar
    Mar 2006
    g-ville
    333
    bump....any help?
    MrSector9's Avatar
    MrSector9 is offline Sparkomatic Rep.
    Oct 2005
    Calgary, AB,Canada
    37
    877
    the pair of 150 would porlly work.
    References - swc204, DiabaseM (carstereos.org), ckyskater733
    NOODPOOPLER IS A PIECE OF LIE'ING BOTTOM FEEDER CRAP
    perrydog's Avatar
    Mar 2006
    g-ville
    333
    what difference does it make?
  9. #9
    perrydog's Avatar
    Mar 2006
    g-ville
    333
    ?bump?
  10. #10
    Feb 2006
    Tampa, Fl
    518
    it changes what frequency the speakers will see. So the lower the number the more bas you'll get from the speakers. Also remember that these numbers will change depending on impedence so if your not using 4 ohm speakers the roll off point will be different.
  11. #11
    Feb 2006
    Tampa, Fl
    518
    what size r the speakers?
  12. #12
    May 2004
    Dramaville
    19,653
    And dont forget its a 6db slope. That means that the roll off is slow. Every octive means that it will be 6db quieter then before. You wouldnt want the 150hz ones for 4" midranges IMO. Depending on the speaker I'd either get the 150hz or 300hz.
  13. #13
    MrSector9's Avatar
    Oct 2005
    Calgary, AB,Canada
    37
    877
    get both and then test to see what you want
