I have a Phoenix Gold 4.0:2 2 Channel amp and it had a 1 30 amp on it. And at a local store they have a amp kit with 8 gauge wiring with a 100 amp Maxi fuse. Will this kit be fine for this amp or no?
2006 Dodge Dakota ST 4x4 Black
Headunit: Clarion DXZ785USB *Sony CDX-GT330 Temp cause UPS lost my Clarion*
Speakers: Alpine SPX-17REF
Speaker Amp: Kicker ZX350.2
Sub: 2 Kicker L7 12" *2 Alpine Type R 12" Temp*
Sub Amp: 2 Kicker 750.1 *Alpine MRD-M501 Temp*
Sub Box: 2 4.5 CuFt @ 34Hz
Wiring: KnuKonceptz
Sold To: Blimblam
my 4 gauge has a 60A fuse on it now..but when i get my 4 channel installed it will have a 100A maxi fuse..but i use 4 gauge..what if u wanna get a 4 channel..stick with 4 guage or bigger..8 gauge just isnt enough..unless you want it and on budget thats fine
it's also dependent on the length of wire
A 100 amp fuse is too high to adequately protect an 8-gauge wire, regardless of length.
For a 17ft run of True 8 gauge (AWG) , 50A is your max load
http://www.the12volt.com/info/recwirsz.asp
http://www.bcae1.com/wire.htm
Wire Gauge-Recommended Maximum Fuse Size
00 awg-400 amps
0 awg-325 amps
1 awg-250 amps
2 awg-200 amps
4 awg-125 amps
6 awg-80 amps
8 awg-50 amps
10 awg-30 amps
12 awg-20 amps
14 awg-15 amps
16 awg-7.5 amps
References - swc204, DiabaseM (carstereos.org), ckyskater733
NOODPOOPLER IS A PIECE OF LIE'ING BOTTOM FEEDER CRAP
thanks alot dewd! My 8 gauge wire is sure to combust any day with a 1000w amp on it and a 80a fuse >_<
Is it cool to split 4ga > 6ga? Seems to me the rule of thumb is even number splits but that might just be common practice as opposed to necessary..?
I'm confused as to what you're asking. You can split to any awg wire, just make sure if you're going smaller, then fuse appropriately.Originally Posted by elementxero
Bookmarks
