Results 1 to 5 of 5
Reload Thread: Wiring a RF Power HX2 at 1 OHM?need help!
    ViCk-BuMp's Avatar
    ViCk-BuMp is offline Senior VIP Member
    Sep 2002
    San Diego CA
    28
    155
    this is the only wiring I have and it's only a 4ohm load but I want to have a 1 Ohm load so please help!!! mine are the Dual 2OHM dvc and the wiring I have for the 4 Ohm load is connecting the wire amp+--------------sub+ amp- ---------- sub- and then a wire with + & - =4OHM,
    but I want 1ohm, how do i get it?
    HU:Clarion VRX925VD AM/FM/DVD Changer Controller w/7" LCD Monitor
    Front: 6.5 Infinity Kappa
    Back: 6.5 Infinity Kappa
    AMPLIFIER Hifonics BX1500D
    ROCKFORD T2 (2000W)
    Steven's Avatar
    Steven is offline Member
    Jul 2002
    CNP
    31
    120
    Wire them in parallel.
    Amp + to both coils +
    Amp - To both coils -
    This will give you a 1 ohm load. I don't recommend this unless your amp is designed to run @ 1-ohm. Most amps are only 4 or 2-ohm stable. So a 1 Ohm load would eventually destroy the amp.
    ViCk-BuMp's Avatar
    Sep 2002
    San Diego CA
    28
    155
    TNX
    But if I buy a JBL 1200.1 or a RF bd1000 they are 1ohm stable, is it safe to run it that way(1ohm)?
    ROCKFORD T2 (2000W)
    Steven's Avatar
    Jul 2002
    CNP
    31
    120
    Should be.
    What happens with amps that aren't 1-ohm stable is too muh current passes through and burns them out.
    A 1-ohm stable amp has the ability handle this current and won't burn out
    Wonderbread's Avatar
    Wonderbread is offline Against Avatar Theft
    Feb 2002
    Vancouver BC
    28
    5,152
    last tiem i checked, teh bd1000 was NOT 1 ohm stable...
    RF doesnt seem to like making amps that like 1 ohm laods....
    the JBL will however be stable at teh ohm load, just make sure that it is ventilated enuf as it is known to get warm to the touch under such a load..
    also, make sure it is getting enuf current..
    4 awg, nuthihng less....
    and it will sucka LOT of current so watch out...
    MSN - pnenis@hotmail.com
    Add me if you have any questions!
    Quote Originally Posted by PT Teal
    I woke up one morning and found a cop at my door telling me he found my car on fire in the middle of the desert.
    Quote Originally Posted by cleanerupper View Post
    Some people have told me that the chrome reflects sunlight, therefore the amp doesn't get as hot as others. Is this true?
