Results 1 to 4 of 4
Reload Thread: Powering 8 speakers using a HU and 4ch amp
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    I have a 92 Cutlass Ciera SL, which has stock 3.5" speakers in the dash and 6x9" speakers in the rear deck. I have replaced the 3.5's and 6x9's with Infinity Kappa speakers, 35 RMS at 4 ohms for the dash, 110RMS at 4ohms for the rear. My Pioneer 8400MP HU is currently powering them. I would like to add a pair of Audiobahn ACX412 4x10" speakers (110RMS at 4ohms) in the door panels (basically the only speaker that will fit), and a pair of Infinity reference 105t tweeters (50RMS at 4ohms) near the window molding. I want to power the 6x9's and 4x10's with a Power Acoustick Sapphire SP4X800 (pushes 85x4 at 4 ohms) and power the 3.5's and tweeters with my HU.
    My questions:
    1) How do I install the 4x10s in my door, since I will have to cut the metal of the door panel and make a custom install? I can handle the tweeter installtion, I have done those before.
    2) I know how to wire the 4x10s and 6x9s, wire the speaker leads to the amplifier leads in parallel, and wire the amp up. The only question I have is, since my HU has 3 sets of preouts (front, rear, and sub) does it matter which set of preouts (front or rear) i hook the RCA cables up to, or does it make no difference?
    3) Lastly, to hook my tweeters and dash up to the HU. Well, the dash are already hooked up, so nevermind about that, but for the tweeters - do I just splice the wires into the now bypassed 6x9 wires?
    Thanks for all the help, it's much appreciated - you guys are teaching me a lot!
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Re: Powering 8 speakers using a HU and 4ch amp
    Originally posted by Gauntlet
    My questions:
    If it were me. I would just build some kick panels and put a pair of midbass drivers in there and be done with it. It would be a whole lot easier. Anyway let's see here
    bad news-It's not going to be easy. Good news everything else is a piece of cake
    You need a template. The speakers should come with a cutout template. First thing you need to think about is mounting location. when considering a mounting location. You need to think about the mechanisms in the door. And make sure the magnet doesn't interfear with them. once you found your mounting location it's just a matter oc cutting the hole out. You can use the supplied grills. If you want to dress them up a little there is several things you could do.
    Your going to use all 4 channels. I would use the front and the rear. Your amp has front and rear rca input's doesn't it ? Go ahead and use them both. You will still have the use of your fader.
    Yeah you can. Just make sure to use a resistor in line to protect them.
    No problem my man. That's what we are all here for.
    5 % equipment
    90 % install
    5% beer
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    My HU has front, rear, and sub RCA outputs. I've only instlled 2 channel amps, so i just assumed that the 4 channel amp would only have 2 RCA connections, guess I was wrong.
    What's resistor in-line?
    Thanks
    Frraksurred's Avatar
    Frraksurred is offline Ubersomethingerother
    Sep 2002
    IA
    45
    454
    A resistor is something you put inline on your + wire between your H/U and Tweeter to block lower frequencies. Your local audio shop should have some, but find out from your tweeter mfg at what freq to begin blocking.
    +t+ FRrAkSuRreD +t+
    Jesus is STILL the answer!
    Alpine CDA-7873 ~ CDT HD-62CF ~ Orion Cobalt 2100's ~ Orion XTR 12" X 2 sealed
