+ Reply to Thread
Page 65 of 65 FirstFirst ... 15 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
Results 961 to 968 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #961
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    4,684
    47 Post(s)
    2430 Post(s)
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by BanginBishi View Post
    Here's the two options: Imgur: The most awesome images on the Internet
    "A" as a note is across the engine bay, next to the battery. (My alt is located on the bottom left side of the engine, woohoo)
    And yes, by "clamp" I did mean sticking the terminal between the plates. Everything is a mess under there now but I'm going to take a wire brush and a grinder once I get going at it. Only issue with doing B is going to be protecting the wire. I'm, uhh, missing 80% of my underside plastics. You know of any particularly weather/erosion proof heat shrink?
    the ground close to the alternator will be much better imo
    while you're in there clean up your factory grounds, its a necessary thing no one does
    can you use that stud you're pointing to with 'alt' as your ground?
  2. #962
    BanginBishi's Avatar
    BanginBishi is offline Junior Member
    Jan 2015
    TN
    21
    12 Post(s)
    Quote Originally Posted by mitchell0715 View Post
    Yes. I was planning on using "Alt" as the first connection. And yeah, I was gonna scrub everything down. It's already been doused in battery cleaner a couple times and I was going to go ahead and pull off the stock connection and do a little sanding under it.
  3. #963
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    4,684
    47 Post(s)
    2430 Post(s)
    you mentioned the wire missing its casing earlier, tbh i wouldnt even use that wiring unless you're referring to stock wiring. in that case i like felt tape, seems like it holds up well. you can tape it then wire loom it
  4. #964
    Jan 2015
    TN
    21
    12 Post(s)
    Are you talking about when I said I was missing my plastics? By "plastics" I meant all of the underside plastic on the car that protects the engine bay from spray and whatnot. Due to the ****** alternator location and the lack of plastics it's going to be really exposed to the elements. I was asking if anyone knew of some really durable heat shrink.
  5. #965
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    4,684
    47 Post(s)
    2430 Post(s)
    oh i see what you're saying, regular heatshrink is fine just tape it up as well. i wouldnt run cheap cca wire under the hood at all, ofc is fine it usually has a good casing and corrosion resistance
  6. #966
    Jan 2015
    TN
    21
    12 Post(s)
    It's 2/0 Flex-a-Prene welding cable. It has a pretty sturdy casing on it, I'm just a bit paranoid. With a run that short I should be able to get enough tape on it to ease my mind.
    Those Raptor terminals I bought off of you look nice by the way. You wouldn't happen to have a box of fuse holders laying around too, would ya?
  7. #967
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    4,684
    47 Post(s)
    2430 Post(s)
    something like that you're usually better off getting on amazon. i like this type, they're usually less than $10:http://www.amazon.com/DS18-FHSANL200...7DMFNSH7B6XMR5
  8. #968
    Jan 2015
    TN
    21
    12 Post(s)
    something like that you're usually better off getting on amazon. i like this type, they're usually less than $10:Robot Check
    Yeah, I was joking around a bit. I've got a couple of DB link holders sitting in my amazon cart right now. One vanished on me and I also miscounted a by a fuse doing my write up. I always forget something along the way. Thanks for your help man.
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 02:19 AM
