+ Reply to Thread
Page 63 of 63 FirstFirst ... 13 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Results 931 to 939 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #931
    Staynlean's Avatar
    Staynlean is offline Member
    Mar 2013
    Memphis, TN
    43
    Re: Official CarAudio.com Big 3 Thread
    Just throwing in my .02 cents. I did part of the big 3 today only thing left to do is alt to bat and I can see a difference. The starter turns over so fast now and dimming is minimal. NOTICEABLE difference and my vehicle is only a 2008 so it's not that old. Can't wait to get my alt to bat finished.
  2. #932
    Chc777's Avatar
    Chc777 is offline Junior Member
    May 2013
    Palm Harbor, FL
    This is the method I used and it works great and was the best way for me too on my 2008 Honda Civic lx sedan. My system is about 1000w so I only used 4gauge wire with 150A fuse to the alt. Had the charging system checked out at as Advanced Auto it read 14.45v no load, and 14.21v loaded with a/c on full and headlights on bright, but I didn't have my system on, I'm not sure what the voltage would be with the system on so I ordered a stinger plug into lighter hole voltmeter are they accurate?
  3. #933
    robertoyoung08's Avatar
    robertoyoung08 is offline CarAudio.com Elite
    Aug 2009
    bay area, ca
    1,173
    Quote Originally Posted by s3th View Post
    I'm talking about a 2010 camaro ******
    its the same thing.
    do a run of 0 gauge from the alternator to the battery in the trunk.
    find a good ground for battery in the trunk.
    ground the engine under the hood to a solid ground.
    same thing, see.
    youd have to do a run of wire to get the power to the amps if your battery was under the hood anyways.
    2005 Lexus GS300
    -Kinetik HC2400, DC Power XP 270 H/O Alternator, Big 3
    -Stock NAV unit w/ 3sixty.3
    -JL HD 1200/1
    -JL HD 600/4
    -Hybrid Audio Clarus front stage; Diamond D6 rear fill
    -2x 10" AA Chaos in 4th order.
  4. #934
    Quinn88's Avatar
    Quinn88 is offline Member
    May 2013
    Eugene, Oregon
    30
    My battery goes to the engine block not chassis so can I just run the other ground chassis to engine block and then it goes engine to battery will this complete the circuit or do I need three grounds as battery to engine block engine block to chassis chassis to battery I just want to get it right I did the battery to engine block and my running volts are 13.8 so that did a lot by its self
  5. #935
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,496
    150 Post(s)
    You can never have enough grounds imo.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - CT - ASE (local) - Batcap - C&D Tech - DC - eD - Excessive Amperage - Rainbow
    In Nashville? Me too! Pm me and come hangout!
  6. Likes Tenacious. liked this post
  7. #936
    Tenacious.'s Avatar
    Tenacious. is offline MAF Whiz
    Apr 2013
    Middle TN
    476
    A new version of this thread with WORKING images should be made...
  8. #937
    Quinn88's Avatar
    May 2013
    Eugene, Oregon
    30
    I just finished my big three upgrade and I'm at 14.8 volts at idle but there is no rises when I rev it up to 2000 or 3000 rpm any ideas to why or should I just not worrie about it cAuse its up so high anyways
  9. #938
    Zavenoa's Avatar
    Zavenoa is offline Junior Member
    Apr 2013
    Northern VA
    25
    Thanks for info, big 3 upgrade successful. Now to see if this does the trick or if I need to go drop another $600 on HO Alt and new batt...
  10. #939
    Zavenoa's Avatar
    Apr 2013
    Northern VA
    25
    2 questions:
    1: The 1/0g wiring I used between alt and batt+ says max load is 375A @ 20', I used 6' between alt and batt with an in line fuse holding 3 100a mini-anl fuses. I think I want to increase these to 120A fuses for a total of 360A, right?
    2: Any harm in running an extra 4g wire from batt neg to ground? Have an open spot on neg terminal cover and enough 4g to run, I have some extra 1/0 but I don't think it's long enough.
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
