+ Reply to Thread
Page 61 of 65 FirstFirst ... 11 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 LastLast
Results 901 to 915 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #901
    Nov 2011
    Dallas, Tx/Ada, Ok
    24
    3,768
    1308 Post(s)
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by jasoncmarsh View Post
    can someone explain where exactly to connect wires to a 2001 malibu to do the big 3?
    throughout all 61 pages of this thread.. im sure thats covered about 186,756,987 times.
  2. #902
    bcdinh's Avatar
    bcdinh is offline Junior Member
    Apr 2012
    KS
    1 Post(s)
    Anyone knows a good website that sells wire by the foot to do this BIG3 job? Thank you in advance!
  3. #903
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,327
    31 Post(s)
    Quote Originally Posted by bcdinh View Post
    AUTOZONE.. Just went in the other day to buy wire lug terminals and found that have various sizes of 4g wire with lugs on both ends for a fair price. I believe its is 20" 36" 40" 60".
    I bought 40" (for alternator power wire) with lugs on it for 7$ or $8. Really heavy duty wire insulation too, good for in the engine compartment.
    I'm sure 4g won't cut it for everyone one, however it is still a huge improvement from your cars 10g or 8g wire.
    Now I have a question. I have no knowledge of engines. What exactly is the engine block and where is it safe to ground on it?
    REFS:
    Sold to- Sky Deaner, Jeeper07, brazilianguy, bjl95mustang, Mr Wiggl3s, Ridinhi (x2), Pootie
    Bought from- kurtdirt1, jmanpc, doingstuffwell
    Traded with- DaGhost, Spooney
  4. #904
    dirtyunclerandy's Avatar
    dirtyunclerandy is offline CarAudio.com Elite
    Feb 2012
    Austin, TX
    537
    163 Post(s)
    Quote Originally Posted by miker View Post
    check out the big three upgrade videos on youtube.
    now 2012 Kia Optima SX
    DD M1C
    Sundown E10s
  5. #905
    _dontaskwhy's Avatar
    _dontaskwhy is offline Member
    Jun 2012
    Moncks Corner, SC
    83
    19 Post(s)
    my wires from the battery to amp are 4awg db link i think its cca. i have a piece of rockford fosgate 4awg but i think its ofc. would it be safe to use that from the alt to the battery? with 100A fuse
  6. #906
    CHEMMINS's Avatar
    CHEMMINS is offline CarAudio.com Veteran
    Aug 2010
    Nevernever Land
    4,091
    479 Post(s)
    Yes. OFC is better than CCA.
    References:
    kmarei, ge_off_me, AudioPipe, slim2fattycake, Louisiana_CRX, ARMed&Bangin, EXTREMECHEVYMAN, Dpc69ss, Psychoacoustics, Shinju, jonny101abc, snoopdan
    BUYING SILVER TOP TRF MOTORS
  7. Thanks _dontaskwhy thanked for this post
  8. #907
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    Ok, here's a quick question on this. My battery is located behind my passenger seat, alt is obviously in the engine bay. I have a jumper terminal in the engine bay that is constantly hooked to the battery via 4ga wiring, so if needed I can get a jumpstart. I was originally going to just run a 0ga from the alt to the positive jumper and then the other grounds as normal. However thinking about it, that 0ga is only going to the jumper terminal and then 4ga to the actual battery. So is it even going to help? I know it would be better just to go straight from the alt to battery, but getting into the cabin is a PITA.
    Current set up: 94 Toyota Chaser (1JZ motor) Kenwood 5907, 3 way active (Alpine DLX-Z30T Tweets, CDT 04's and 06's), Helix P Six DSP/Amp, 4 IDQ12's, MMATS D3000.1
    66 Pontiac GTO, modified stock radio, Crossfire CFA 302, Kicker KS6.2's in the front kicks, Crossfire CFA 452 for the 6x9's I need.
  9. #908
    Jun 2012
    Moncks Corner, SC
    83
    19 Post(s)
    thanks
  10. #909
    ace_800's Avatar
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    Quote Originally Posted by ace_800 View Post
    Anyone gone an opinion on this?
  11. #910
    ace_800's Avatar
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    bump
  12. #911
    husker77's Avatar
    husker77 is offline CarAudio.com Elite
    Apr 2012
    Nebraska
    662
    267 Post(s)
    I'm not sure how your vehicle is set up exactly, but my wife's olds aurora was the same way. But no it isn't going to do a lot of good if you don't run the 0awg to the battery also. It might help just because I am guessing the jumper terminal is on the fuse/relay box, and most of your wiring is attached to that for the vehicle, so you may gain a little by just running to the jumper. But if you have a fairly serious system you may tax that 4awg from your battery to the jumper, it will be your weak link.
    Now a little disclaimer, I do not know exactly how your vehicle is wired or what you have already done, but this would be my opinion based on the little info I have.
  13. #912
    ace_800's Avatar
    May 2004
    Okinawa, Japan
    37
    5,421
    4 Post(s)
    503 Post(s)
    Quote Originally Posted by husker77 View Post
    My jumper terminals aren't connected to the fuse/relay box, its separate from everything. I'm running about 2krms right now, I could bump up to 3k with the same amps, but not really any plans to do so anytime soon. I don't have any dimming, but I do notice my voltage dip to about 13.5 once in a while, hence why I was wanting to do it.
  14. #913
    husker77's Avatar
    Apr 2012
    Nebraska
    662
    267 Post(s)
    If it is separate from everything then it wont really do any good at all.
  15. #914
    husker77's Avatar
    Apr 2012
    Nebraska
    662
    267 Post(s)
    If it is separate from everything then it wont really do any good at all. Like I said on my wife's aurora the jumper was part of the fuse/relay box and the car wiring was attached to it.
  16. #915
    gb22's Avatar
    gb22 is offline Member
    Jul 2010
    IN
    46
    3 Post(s)
    delete
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
