+ Reply to Thread
Page 59 of 63 FirstFirst ... 9 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 LastLast
Results 871 to 885 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #871
    Vital's Avatar
    Vital is offline Member
    Mar 2009
    NY
    73
    Re: Official CarAudio.com Big 3 Thread
    2 questions:
    1. Do my chassy to engine block wire need to start at the same point as - battery to chassy wire ends so it's basically a continuation of it?? Or can i start runnig my chassy to engine block a few feet away from the point where -battery wire ends??
    2. where do you guys buy wire loom for 0g wire?? I'm gonna use Rockford's 0g and every wire loom i've found is either too big or too small.
  2. #872
    connersdad19's Avatar
    connersdad19 is offline CarAudio.com Veteran
    May 2007
    Logan, Ohio (43138)
    27
    4,351
    Quote Originally Posted by Johnsonmn2 View Post
    I know this is probably in this thread 90 pages ago but when doing the big 3 do you have to do the wires to the fuse box also? Or could I just skip the alt to fusebox, and go straight to the battery with an added inline fuse?
    you can go from the alternator straight to the battery. I dont see it being a problem, as you are just adding.
    REFERENCES
    http://www.caraudio.com/forums/buyer-seller-feedback/239110-connersdad19s-references-6.html#post7494382
    I will NEVER ship anything with UPS again. I ask that you NEVER ship me anything with UPS please.
  3. #873
    robertoyoung08's Avatar
    robertoyoung08 is offline CarAudio.com Elite
    Aug 2009
    bay area, ca
    1,172
    for referance and for easier referance:
    1. battery ground to chasis= yellow
    2. battery positive to alt positive= red
    3. battery ground to engine ground= white
    4. intake manifold to chasis ground= blue
    now step by step:
    this is the easiest and quickest to do of the big three. took off the bolt and sanded it down, placed the wire back in and bolted it back on.
    this one was a little more work. i found the best way to do it was to lift the car up on ramps. take off the black plastic cover right under neath the engine and work both above and under car. but it could probably be done with out unscrewing the bottom plastic cover.
    pretty simple also. bolt and wire are pretty easy to spot. pretty much right next to alternator. also did it while i had the plastic cover right underneath engine cover taken off. this bolt is facing down towards the ground when your looking down on the engine standing up. so you'll have to get underneath the car and take the plastic covering off to get to it.
    full shot:
    close up:
    second to easiest connection to do. just have to make sure to route carefully, because the hoses around it get extremely hot and we dont want the 0 gauge to melt or cause a possible fire.
    summary with all wires in view (color coded):
    so this was the big three. hope it helps. tried to do it step by step and did some color codding. i know a bunch of wires that look like the rest of the other wires can b a little confusing to follow in the mess of an engine bay. hope it helps. il post a few more later of my finished product once my wires are connected witht he battery terminals and not just sitting there.
    heres a before and after i had the zero gauge ran:
    before:
    after:
    2005 Lexus GS300
    -Kinetik HC2400, DC Power XP 270 H/O Alternator, Big 3
    -Stock NAV unit w/ 3sixty.3
    -JL HD 1200/1
    -JL HD 600/4
    -Hybrid Audio Clarus front stage; Diamond D6 rear fill
    -2x 10" AA Chaos in 4th order.
  4. #874
    devin601's Avatar
    devin601 is offline Member
    Sep 2009
    Hattiesburg, MS
    30
    I did the BIG 3 yesterday and forgot to do the chasis to engine block. Is that ground necessary as it seems like you just grounding a ground. If so why? and is the chasis just and metal part under your hood?
  5. #875
    Carnivorous18's Avatar
    Carnivorous18 is offline T3h G33k
    Jul 2009
    San Diego, CA
    21
    460
    Quote Originally Posted by devin601 View Post
    Yes it is important, it keeps all loopholes closed as far as larger amounts of power going through the positive wires, but then having a restrictive route back from the negative because the wire is smaller than the 0 gauge on the other 2. The chassis is considered one of the screws that go around the outer lining of your engine bay/hood. Look around that edge and look for a wire already connecting to the engine block somewhere. Thats where you should put on the extra 0 gauge ground. Also take some sandpaper before you put it on and sand off around that bolt hole for the chassis ground
    My car: 1999 Honda Civic EX EJ8
    System: 2 12" DC XL (not installed) ~Amp: Sundown SAZ-3000D
    XS D5100R & XS D3100
    DC Power Engineering 180amp HO Alternator
    HU: JVC KD-A815
    Front & Back Stage: ID CTX65CS on MB Quart Onyx4.60 @280w per channel
    Thanks to Don @ SoundDeadenerShowdown I shouldn't be rattling
  6. #876
    phrostbyte0311's Avatar
    phrostbyte0311 is offline USMC Veteran
    Jan 2011
    Modesto, Nor Cal
    29
    106
    Quote Originally Posted by tuckintaco93 View Post
    also if your going to start something like this dont delete your pics from your pic hoster
    I agree totally!!
  7. #877
    May 2007
    Logan, Ohio (43138)
    27
    4,351
    why do people keep on b1tching...its not rocket science....
    REFERENCES
  8. #878
    cable729's Avatar
    cable729 is offline Junior Member
    Mar 2011
    Windsor, CO
    All the images are gone. Please fix
  9. #879
    Aug 2009
    bay area, ca
    1,172
    Quote Originally Posted by cable729 View Post
    not my pics.
    2005 Lexus GS300
    -JL HD 1200/1
    -JL HD 600/4
  10. #880
    cvplaya23's Avatar
    cvplaya23 is offline Junior Member
    Apr 2011
    peterborough, NH
    i have an 05 cobalt with two 12in type rs in a ported box powered by a precision power amp. when i have the volume all the way up and the subs are bumpin more times than not the subs cut out and the amp shuts off. when the they shut off i can turn down the volume and the amp turns on and the subs start bumpin again. when the amp shuts off niether the short or thermal lights come on. i cant figure out what it is. im thinkin its my battery, electrical or alternator. does anyone have any solutions
    is it because im having voltage drop?
  11. #881
    mrToester's Avatar
    mrToester is offline Member
    Mar 2011
    Southern JErsey, next to philly
    72
    ^^^ Cap it?
  12. #882
    its10v1's Avatar
    its10v1 is offline The Caped Rock-Head
    Jul 2010
    Flint, Murda-Mitten(Mi)
    21
    395
    5 Post(s)
    Icon32 Re: Official CarAudio.com Big 3 Thread
    I guess I answered my own question.
    Last edited by its10v1; 04-16-2011 at 02:34 PM. Reason: narrow minded-ness prevails?
  13. #883
    tigersdl65's Avatar
    tigersdl65 is offline Junior Member
    May 2011
    Tallassee, AL
    This was a huge help.
  14. #884
    jamesmington's Avatar
    jamesmington is offline Senior VIP Member
    Aug 2007
    houston
    176
    Quote Originally Posted by connersdad19 View Post
    So we don't need an inline fuse either, right?
    References: diver_dylan, frito, vitas
    Hemiscott takes your moneys.
  15. #885
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Quote Originally Posted by jamesmington View Post
    it wouldn't hurt to have one but you don't really need it
  16. Thanks jamesmington thanked for this post
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
