+ Reply to Thread
Page 58 of 63 FirstFirst ... 8 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 LastLast
Results 856 to 870 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #856
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    14,053
    10 Post(s)
    Re: Official CarAudio.com Big 3 Thread
    Brah, you can keep making any assumptions you want, there's a reason that every single veteran on this board recommends the big 3. The less resistance you have in your electrical system, the more power your going to get out of it, period. If $10 for a piece of wire is too expensive for you then by all means skip it, but in a world where people drop hundreds (thousands) of dollars on equipment, cheaping out on the electrical side is how things get blown.
  2. #857
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,041
    2 Post(s)
    Quote Originally Posted by tuckintaco93 View Post
    also if your going to start something like this dont delete your pics from your pic hoster
    Quote Originally Posted by bubbagumper6 View Post
    ...cheaping out on the electrical side is how things get blown.
    this. plus all my wire was free
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  3. #858
    dman4486's Avatar
    dman4486 is offline Paid to Post
    Jan 2008
    Central, SC
    9,333
    bunch of whiners in this place now
    Auto: 96 honda passport 3.2L v6 4X4 5sp
    Big 3 pics--THE MAV--THE RSD's--MY VLX
    Rices Creek Pics
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
  4. #859
    d2k's Avatar
    d2k
    d2k is offline Senior VIP Member
    Sep 2010
    uk
    469
    instead of running out 0AWG onto TB3, could i just leave the existing 4AWG runs & then add 3 runs of 8AWG onto the connections..??, so 1x 4AWG & 1x 8AWG per connection..??
    im thinking the difference between changing the 4AWG for 0AWG will be pretty much the same as what i described above..?? no..??
  5. #860
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,041
    2 Post(s)
    Quote Originally Posted by dman4486 View Post
    hai
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  6. #861
    Apr 2006
    The D
    14,053
    10 Post(s)
    Quote Originally Posted by d2k View Post
    What is TB3?
    I already said to leave the stock wires if you can and just add on, but I definitely wouldn't add 3 runs of 8 AWG that's just dumb, do 1 run of 1/0 and be done with it, then you don't ever have to worry about upgrading it again (unless you go huge in the future)
  7. #862
    d2k's Avatar
    d2k
    Sep 2010
    uk
    469
    What is TB3?
    ''the big three''....
    right...... cheers!!
  8. #863
    ctmaudi's Avatar
    ctmaudi is offline Senior VIP Member
    Sep 2010
    Akron, OH
    374
    Do the ground wires need to be less then 3ft like with ground wires from an amp? I cant really find any engine block bolts within 3ft of a chassis ground.
    Bought From : BumpinKota (PA P2250D), mmouse57 (wire), Massiveaudiocw (2xSA10s), Slayerx (DSC480, GM-5400t), Outsideshot23 (wire), cdimic25 (HC600), Pro-Rabbit (box)
    Sold To : Spooney (PA P2250D), nd_6037 (GM-5400T), Heeltoeclutch (distro/RCAs), BlactimusCrime (Kenwood HU)
    Other Refs : EOCF.com itrader (cecil), heatware (cecil), ebay (ctmaudirs6)
    2007 Altima 2.5S Sedan - Kenwood KDC-X794 - Crescendo CCX65 - Onyx-480 - AA Havoc 12 D2 - Onyx 1500D - 2.25 net @ 31Hz
    Stock 110amp alt - stock battery - 1/0 kicker hyperflex back to Kinetik HC600 - 1/0 Knu Kolossus Big 3
  9. #864
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    Quote Originally Posted by jco1385 View Post
    hai
    Rices Creek Pics
  10. #865
    Apr 2006
    The D
    14,053
    10 Post(s)
    Quote Originally Posted by ctmaudi View Post
    No, it's just generally a good idea to keep them as short as possible. The point of grounding the engine block is to ground the alternator chassis so if you can easily use one of the alternator bolts, go for it.
  11. #866
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,041
    2 Post(s)
    and your engine block is setting ON the friggin chassis. if you can't find a bolt within 3ft, you got a huge ass engine and or car.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  12. #867
    Slayerx's Avatar
    Slayerx is offline CarAudio.com Elite
    Sep 2010
    Sacramento
    1,541
    20 Post(s)
    So if I'm gonna do my pos alternator wire, and I have an external regulator, I need to somehow go through it? Never done an ext. reg. before
    2000 Acura TL
    Pioneer DEH-80PRS
    JBL MS-62C
    Kicker CX300.4 (Temporary)
    Subs TBD (IAD 10" or 12" possibly)
    Eclipse XA1000 (Till I need/want more power)
    Sold to: ctmaudi, Trancer, Germ305, RAM_Designs, lrc131
    Bought from: gentlejax, 2lows10, eL_wEEnIe, --Navi--, wu501, trumpet
    Quote Originally Posted by Tony30cl View Post
    i turned my pornhub off for this
  13. #868
    ctmaudi's Avatar
    Sep 2010
    Akron, OH
    374
    Or, a heat shield is in the way, and Id rather not melt wires by taking the shortest route.
  14. #869
    DonH's Avatar
    DonH is offline .....
    Jun 2008
    So Cal
    5,809
    35 Post(s)
    true. btw i got your pm about the wire i have FS i still have it....
    Quote Originally Posted by chillin View Post
    How do you bridge a mono?
    Quote Originally Posted by snoopdan View Post
    throw it off one.
    feedback thread:
    http://www.caraudio.com/forums/buyer-seller-feedback/402726-d-man1s-official-feedback-thread-2.html
  15. #870
    Johnsonmn2's Avatar
    Johnsonmn2 is offline Junior Member
    Feb 2011
    minneapolis
    I know this is probably in this thread 90 pages ago but when doing the big 3 do you have to do the wires to the fuse box also? Or could I just skip the alt to fusebox, and go straight to the battery with an added inline fuse?
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
