+ Reply to Thread
Page 57 of 63 FirstFirst ... 7 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 LastLast
Results 841 to 855 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #841
    smokingachicken's Avatar
    smokingachicken is offline Junior Member
    Jan 2007
    Anaheim, CA
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by bubbagumper6 View Post
    uhh....I don't see any pictures
    its actually on the page previous to the one the link takes you.
    Quote Originally Posted by jco1385 View Post
    fuckin n00bz
    as far as noobz, nobody wants to go trough 56 pages to find pictures. Especially when 50% of all the post are people like you complaining about noobz.
  2. #842
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,035
    2 Post(s)
    link works for me. post numbers 571 & 581
    you shouldn't need pictures, btw. it's easy as pie. pos battery post looks like pos battery post, alt post looks like alt post, etc...
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  3. #843
    grandam888's Avatar
    grandam888 is offline Senior VIP Member
    Dec 2010
    houston, tx
    24
    445
    did big 3 yesterday. Funny how who ever ghetto rigged my wiring before i owned it used 8 gauge to block from ground, 10 gauge to fusible link from alternator, AND SOMETHING LIKE 14 GAUGE from battery negative to chassis. I couldn't believe it when i saw it. basically my only goo negative was from block to battery. Ran 3/0 everywhere now.
    i was dropping to 12 volts @ idle with a 800 watt amp running, not i don't even dip below 13.5 @ idle doing about 14 volts cruising down freeway.
  4. #844
    Vital's Avatar
    Vital is offline Member
    Mar 2009
    NY
    73
    About to do my first BIG3 which is very simple but not when it comes to fuses.
    I always see "make sure to have a fuse next to your battery that whould match amps from the alternator" in every big3 "how-to"
    Here's what i don't understand - alt is what's powering the battery, not the other way around. So current is coming FROM alt to bat which logically means that fuse should be next to the alternator, not battery, no ?
    If you look at it further (and correct me if i'm wrong on this) in case anything happens to the wire and let's say it gets cut somewhere in the middle of it's run battery will now pump jiuce out of it just like it does with any other wire connected to it's positive terminal post. SO there should ALSO be a fuse next to the battery. Not sure how many amps fuse but i'd guess the same as your "next to alt" fuse.
    Yes? No? Am i missing something here?
  5. #845
    Vital's Avatar
    Mar 2009
    NY
    73
    ^^^ anyone??
  6. #846
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,035
    2 Post(s)
    i don't have a fuse on that wire and have never had a problem. BUT, if i was going to fuse it i would do like you are saying so that it would effectively 'kill' that wire in the event it was overloaded. i just routed mine where it is out of the way of everything.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  7. #847
    flatland's Avatar
    flatland is offline Member
    Feb 2011
    Louisville KY
    36
    Can I just use a circuit breaker for my alt to battery connection instead of a fuse holder? I have one circuit breaker for my audio system and would like to keep it all uniform if possible
  8. #848
    bubbagumper6's Avatar
    bubbagumper6 is offline CarAudio.com Veteran
    Apr 2006
    The D
    14,049
    10 Post(s)
    Quote Originally Posted by flatland View Post
    Eh, you can but every time you trip the breaker it gets weaker and weaker. Also I'm not sure if you'd be allowed to compete with that in (if you even want to). Fuse holders & fuses are cheap and easy to swap out for different amperages, I mean there's a reason 99% of us use them.
  9. #849
    flatland's Avatar
    Feb 2011
    Louisville KY
    36
    That's good to know, so thank you!
    I haven't used it yet, but I'm sure I can send it back, and get a credit towards a fuse holder style.
    Thanks agin
  10. #850
    Apr 2006
    The D
    14,049
    10 Post(s)
    Yeah no problem, you can get no-name nice ANL fuse holders on ebay for cheap (like $10 shipped each).
  11. #851
    SmartAsss's Avatar
    SmartAsss is offline Member
    Jan 2011
    Buckeye
    145
    Anywhere in this long post did someone mention that only the big 2 (ground wires) is needed unless a hi-output alternator is installed? The factory wiring is enough for the factory alternator..it has to be otherwise the thing would catch fire. Saves some money on fuse, wire and terminals. In case anyone cares.. Ill probably be flamed for this comment though.
  12. #852
    tuckintaco93's Avatar
    tuckintaco93 is offline Senior VIP Member
    Dec 2010
    holt , fl
    285
    also if your going to start something like this dont delete your pics from your pic hoster
  13. #853
    Apr 2006
    The D
    14,049
    10 Post(s)
    Quote Originally Posted by SmartAsss View Post
    Uhh, upgrading the stock alt cable will give less resistance which would mean less of a voltage drop. Just because the cable is able to handle the current doesn't mean it isn't corroded to hell and causing a bad voltage drop.
  14. #854
    azphat12's Avatar
    azphat12 is offline Senior VIP Member
    Feb 2010
    Arizona
    264
    Personally I would just do all of them. You will already be under the hood, and to get a 5ft cable and a fuse and holder isnt that expensive.
    2008 Honda Civic SI coupe
    Alpine CDA - 9887
    Boston Acoustics SC60 6.5 components (2 sets)
    Rockford Fosgate T600.4
    Rockford Fosgate T1000.1
    2 JL Audio 12W3-v2
    Optima Yellow (stock location)
    Knukonceptz wiring
  15. #855
    SmartAsss's Avatar
    Jan 2011
    Buckeye
    145
    You're correct about the corrosion, this is very possible, but assuming that the cable is in halfway decent shape, then this is really not an issue. the issue is really with the ground straps which are much more prone to corrosion.
    A voltage drop of even as much as .5v is not going to make a difference in the sound or output. If the system is too weak, it is just too weak. adding the alternator cable is not some sort of miracle cure for electrical systems as its touted by so many people on here.
    example.. 13.5v x 100amps = 1350w. 14v x 100amps = 1400w. A gain of 50w in a 1000w + sound system will translate into zero audible gain. to have an audible gain, you would need double the wattage 2000+.
    Personally I would just do all of them. You will already be under the hood, and to get a 5ft cable and a fuse and holder isn't that expensive.
    I hear that, but Ive seen many posts asking about "do i really need a fuse on my alt cable" and I'd rather see someone omit the alt cable if they don't have a fuse then to put a big cable on without it. to some people $10+ dollars is money better spent else where. and safety is priceless.
    think of it this way. you could beef up all of your wires in your car, what would it gain you if they are already sized properly? lower resistance across the board, but it would have no effect on how everything operates.
    People will do what they will, I'm just trying to let people know the theory behind things. Im not going to discuss this any further because its really not that big of an issue, just thought Id mention it. It's just not a must have item.
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
