Images don't work.
Images don't work.
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Auto: 96 honda passport 3.2L v6 4X4 5sp
Big 3 pics--THE MAV--THE RSD's--MY VLX
Rices Creek Pics
Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
Does a cable go from engine block to negative battery cable with big 3?
my jeep grand
Jeep Grand Cherokee 2000
SONY XPLOD CDX-GT420U,
Power Acoustic BAMF 5500/1 Amplifier,
2 Type R 15 Dual 4ohms,
Ported 7.07'cu Tuned 34hz
KnuKonceptz Silver Pearl 1/0 + 4 Gauge Wires,
Big 3 1/0 Gauge wire.
2 Kicker Distribution Block DB1448,
Fuse Holder ANL 300amp,
Dash + Wiring Kit.
my camaro
Dash + Wiring Kit.
Dash + Wiring Kit.
you should clean your grounds on the jeep. the camaro grounds look fine though.
I thought that was some type of putty....
grounds on both cars are clean
Dash + Wiring Kit.
http://www.youtube.com/watch?v=p82xRzCr-lc here is a video I thought might be helpful to some.
Sony Mobile ES C-90 Audison Bit-One
Audison LRx 3.1 MT
Hertz HSK 130
Mid Bass ?
DB Drive K5 15
Kinetik 1400HC
avital 2200 alarm
dynamat extreme
Question about the Alt (+) to battery (+) connection. Doesn't the stock wire from the alt (+) go to the starter & ignition then to battery (+)? Would running an additional wire directly from the alt (+) to battery (+) cause problems for the stater or ignition?
Sorry havent had time to go thru all 49 pages of this thread yet, this connection makes me a bit nervous to fry something.![]()
no it will be fine. it says in there a couple times that it will be ok to do
Bookmarks
