+ Reply to Thread
Page 34 of 65 FirstFirst ... 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 ... LastLast
Results 496 to 510 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #496
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by jco1385 View Post
    you should have 3 neg wires at the battery.
    1. stock wire
    2. engine ground 1
    3. chassis ground 2
    4. IF YOU GROUNDED REAR BATTERY TO FRONT BATTERY
    you should have 3 on the positive side at the battery
    1. stock wire
    2. alt to battery 3
    3. run to the amp. (or rear battery)
    am i missing something?
    those are the BIG 3 in green
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  2. #497
    PuZo's Avatar
    PuZo is offline Senior VIP Member
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    So leave the stock negative, unless I can differentiate the one that goes to the chassis, and then all power will be new wires?
  3. #498
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    why do you need to remove the stock wires? what terminals you got?
    the list i made is very easy to understand.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  4. #499
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    just post a pic.
    that will save me ~2hrs trying to explain
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  5. #500
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    Currently I have 2 cables connected to the negative and 1 to the positive, this is ALL STOCK. When I do the big 3, what do I do with the stock negative cables? Since one might go to a fuse box or something, I need to leave it connected right? I am getting a battery terminal(3 way) and with that is gonna be connected 1 wire for a 2nd battery, 1 to the chassis. My positive will have 1 for the 2nd battery, 1 running the power to the back and 1 going to the alternator.
    So do I leave the stock negative cable connected?
    Posting pics, btw also noticed I have 2 wires going from my positive terminal as well.
    Negative
    Positive
    The one ontop is the power running to the d-block, but you cant see so clearly but it does split up into 2 separate cables.
    So do I replace the stock wire for the positive terminal going to the alt and leave the other wire connected?
  6. #501
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    i would trace those negs down. one probably goes to the engine block. the other... idk. you should be able to take the stock negs out. (this is assuming you have big 3 done)
    as for the pos. one almost def goes to the starter (or a fuse box) this one will need to stay. or maybe one goes to the starter, one to a fuse box.
    trace them down and see what they go to, if possible. if not, just leave them.
    what car is this?
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  7. #502
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    96 camry and big 3 is not done. Can i just leave all those cables there and say where the pos goes to the alt just cut the original cable and like tape it off so its not a live wire?
  8. #503
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    why would you do that? why not just leave it?
    is it a cosmetic thing? because current will flow through least resistance so the smaller wire will be useless, but it won't hurt to leave it. and it'll look better w/o taped up wires and such.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  9. #504
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    Just making sure, but then wouldnt i have 2 wires going from pos to alt, stock and 1/0? Would they both fit?
  10. #505
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    mine fit. idk you'll have to see. if not, just take the stock one out. but don't just cut/tape it.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  11. #506
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    K so either keep both or permanently remove it, but still leave the other cable that goes to the starter or fuse box or wherever. But as you can see in the pic they are both connected to 1 clamp/terminal, so should I make a new one, or just cut it off as close as possible?
  12. #507
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    cut the old terminal off, strip back the wire and put it on the new terminal.
    yes keep the one that doesn't go directly to the alt.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  13. #508
    PuZo's Avatar
    Jan 2008
    Toronto, Canada
    424
    33 Post(s)
    What size dupe should i use for the alt to pos? And what size fuse for my 2nd battery, the fuse would only be on the pos wire right?
  14. #509
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    dupe? you mean fuse? i wouldn't worry about fusing the alt -> battery wire.
    and you want 2 fuses between batteries. one at the front. one at the rear. for 1/0 i personally use 300a ANL front and back.
    and yes, fuses go on positive wires.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  15. #510
    chaplin's Avatar
    chaplin is offline Junior Member
    Oct 2008
    Shenzhen,China
    Hi guys,I have just bought a car DVD player from the site gizmograbber.com for myself.It's pretty good.Are you interested in Car audio,car video and DVD player?
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
