+ Reply to Thread
Page 31 of 63 FirstFirst ... 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 ... LastLast
Results 451 to 465 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #451
    Racerx250's Avatar
    Racerx250 is offline CarAudio.com Veteran
    Mar 2007
    Houston,Tx
    24
    2,212
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by mackallmike View Post
    what size fuse should use for the alt to batt.i used rockford 2 ga wire i have 100 in there right now my alt is 130 amp??????
    fuse the amperage rating on the wire. Not the load going through it.
    Bought from - Shallowfu mattmcss bholtmeier apw122 cam5860 KINGDELL91 impalafan95 six501 skydeaner Amalan Datboiroy X5(met in person) dalucifer lrc131 tEh koRnDog civicsimomo JoeSmith502 matthewo Cguth hessdawg lilmaniac2(X2) lil_italy773 na_rsx tdeaton1021
    Traded With - Beerdrnkr freezeman_7 cd6551 SoCalBean420
    Sold to - vitveet memphisflex Blinkdogo2 kruler
    There's more but I can't remember who.
    Up Coming plans for my silverado
    9887(still need)
    6.5 ID OEM, Hertz HT30 tweets, Sundown 100.4
    Sundown 1500(still need), (1) 2005 12" RE XXX
    2.5cu. ft. @ 32(still need)
    2 yellow tops
  2. #452
    mackallmike's Avatar
    mackallmike is offline Member
    Jul 2008
    MD
    136
    what size fuse should i use when i used 2 ga for my big 3????????
  3. #453
    boomzilla's Avatar
    boomzilla is offline Got 'Roids?
    Mar 2008
    Florida
    23
    1,262
    250-300 amp fuse
    - 12'' Fi BL Fully Loaded - 2.2 cu. ft. box @ 35hz - 29 sq. in. of port - Stinger SPV 44 - Us Amps Merlin MD3D @ 2ohm - 5.25'' PG RSD Components - Big 3 in Hyperflex 1/0 - Pioneer DEH-3000IB - 140 sq. ft. of Stinger Roadkill Expert
    Refs: Slam, Ridinhi, Blados, Pioneerpimp, Kowboy
  4. #454
    TurdFergueson2's Avatar
    TurdFergueson2 is offline Team D.O.A.
    Aug 2007
    Chicago
    7,046
    Didn't want to start another Big 3 thread, but I was wondering if there was any benefit to doing more than 1 run for it? like if I got some of these
    http://cgi.ebay.com/Stinger-Dual-0-G...QQcmdZViewItem
    the one off of the alt+ to batt + would be fused twice too. Has that ever been done?
    Sold to: Rc10Mike, Philpbak, pbnj123, WALKSUP, silvercookie, Sir Smoke Alot
    Bought from: Korn4life, chaunb3400, fasfocus, mlstrass, Bumpin Buick, wheeler8921, annarbor84
    Quote Originally Posted by Cameron_B View Post
    I pulled into the trailer park at around 3 am bumping my sony xplod 12 on sony amp. **** SLAMS!!!!!! Anways, I pulled up and it got all the girls wet.....I guess im an uncle and a dad now
    Don't listen to all the haters, their shiz doesnt knock...EDIT: Ohh yea, and by the way....before you haters start mouthing, I got my SLAB from wall-mart....that ish doesnt bang it XPLODES. Yea..I run sony... Schoche -SP box with 4 inch PVC downfiring into pasenger wheel well. 5-6 inch streamers...
  5. #455
    Fusion_FREAK's Avatar
    Fusion_FREAK is offline Story of My Life...
    Oct 2007
    in the garage
    3,249
    I don't think it would be needed, unless you have like 3 or more alts producing over 400 amps of current, but it wouldn't hurt.
  6. #456
    99grandprixGT's Avatar
    99grandprixGT is offline now got an 04 grand prix
    Jul 2007
    home
    23
    10,598
    would it be ok to use the strut bolts as the grounding spot? how about grounding both the battery and engine block to ground at the same spot?
    refs:
    wong05tsx, Buckyboy, Themommyvan, Team H&K, natisfynest(x2), Eat Italian,NewAgeKing, skierxx5556, wgsj_fortvalley, MmatsDude, bigpimpin91 ,wasted ink, JLbumpin04gp,itsbmw(x2),ltr450racer690, speedfreak28,jshak07,xplayazplayzonx,mcsoul, SPL-Master ,TNTR70, bumpin buick, vitveet, gqjeff, pioneer pimp ,bones22, nismos14, revrider1,bigbirney420,nineball,DBDRAGGUY ,plyer3,slam330, BeAlLsTaR13, smllysack,Andrew_as. dkhage1,boxdGM, blue200sx,rusty_armadillo, beatnbronco, basscort2009,xxxbasshead,SSS 18734,mcquesten
    feedback
  7. #457
    x2o's Avatar
    x2o
    x2o is offline Fuzzy Blue Lights
    Nov 2007
    Miami/PSL, FL
    3,714
    Quote Originally Posted by 99grandprixGT View Post
    I have my battery and block grounded at a common place and it's been working fine.
    As for the strut bolts question, it depends on the car. As long as you can get a clean contact with the chassis your fine.
    The System :
    Electrical: Big 3, Powermaster D1200 and D3100.
    Sub Stage : 18" Custom Sundown Nightshade D2 Tuned to 30 Hz
    Sub Amp : Sundown SAZ-3000D
    Headunit : Alpine 9887 (ACTIVE )
    Front Stage : (2) Eminence Delta 10" mids, 2 Power Acoustik NX-5s
    Rear Pro Audio: (4) 8" Selenium 8W4P, (2) Selenium ST350
    Pro Audio Amps: Hifonics ZXi6010, Hifonics ZXi1010, Kicker ZX350.4
    Wiring : Kicker Hyperflex/Knu 0ga/RCA's
    Refs : Apocalypse Boy, Brian Owens, JBLCamry, ABSOLUTEAUDIO, BushJ311, tEh koRnDog(x2), blackbonnie, ProjectPat06, ampjunkielikeme, DownSouth954, Tapout, PaulThompson229, Mrogowski, Team H&K (Kent), andrewmoore13, slam, 100% eBay
  8. #458
    Oct 2007
    in the garage
    3,249
    I use my rear strut bolts for ground, so the front should be fine. As far as grounding at the same spot I'm not sure. All my grounds are in different places. I imagine it shouldn't be a problem though, just make sure it's a clean surface with no paint on it.
  9. #459
    Jul 2007
    home
    23
    10,598
    all right thanks.
    refs:
    feedback
  10. #460
    TerryS1980's Avatar
    TerryS1980 is offline Do It To Em
    Aug 2008
    South Louisiana
    Quote Originally Posted by Racerx250 View Post
    Shouldn't the fuse on the wire going from Alt to Batt match the size of the factory fuse under the hood. In my case 2000 Explorer was 175A.
  11. #461
    wat's Avatar
    wat
    wat is offline Senior VIP Member
    Jun 2008
    Colorado
    386
    Quote Originally Posted by TerryS1980 View Post
    no. the fuse should match the size of the wire it is fusing.
    Quote Originally Posted by Goob View Post
    Call me 3366482278
    Quote Originally Posted by SSS 18734 View Post
    Make sure to apply the product liberally and then vigorously rub it out. It may take several tries to get the results you want.
  12. #462
    1rockford1's Avatar
    1rockford1 is offline Banned
    Aug 2008
    soon to be upstate ny
    12,729
    when doing the big 3 do i need new battery terminals. for + - ? and when running the wires its just adding not splices right. with a new alt do i bother connecting the old wires to the alt?
  13. #463
    1rockford1's Avatar
    Aug 2008
    12,729
    ok i just went out side and i found my alt to postive connection. then i have my battery to ground, can i use the stock location its a little bolt thats about 8 inches away from my neg of my battery? and the block to chasiss the bolt is on my alt brace on top. its about a foot away from the my chassis . do i have to sand down the paint all the way for a good ground? and if i use 0 ga wire will the connecter fit on the bolt from my alt and battery . its i think 5/16. ones i connect my battery will there be a spark or anything. and for the really stupid question can any thing really happen as far as my battery draing faster cuz of the new wire? im gona do a new battery well i have the terminals off. thanks i really wana do it now i think i can just go out there and get it done.
  14. #464
    leon's Avatar
    leon is offline Member
    Jun 2006
    denver
    132
    can someone repost the pictures? i'm a retard
  15. #465
    bryce-man's Avatar
    bryce-man is offline CarAudio.com Elite
    Feb 2007
    beach cities CA
    1,181
    Quote Originally Posted by TurdFergueson2 View Post
    my big three is double 1/0 all around
    its been great
    i had just enough extra to do it so i figured why not?
    its just less resistance so more voltage and amperage can pass
    i gained .5 volts with the truck on and off
    Refs
    Bought from
    CA --orioles26,97cavy(ups=crap),mike dressure x2,rtillaree,gordos420,ultimate157,pioneerpimp,Pim pdaddyq,Anonymous User,thatkidbob,amartin_72,snoopysnooper,hemi=22s, dvrmstrng,revots,nathan from EA,Adrianos,JRsmoothie,flexxissues
    Ranger-Forums.com --Ranger1
    Ebay --johnbryan67,knu, and countless stores
    Sold to
    sanmaim,SWEET06CAMRY,mud
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
