+ Reply to Thread
Page 3 of 63 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 53 ... LastLast
Results 31 to 45 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #31
    thai_creeper's Avatar
    thai_creeper is offline CarAudio.com Elite
    Feb 2006
    bay area, ca
    955
    Re: Official CarAudio.com Big 3 Thread
    x2, i was wondering about that too, I think I see them without the fuse too, couldn't you just stack up the wire terminals and put the bolt over them?
    References: flakko(bought from), psyrex(sold to)
  2. #32
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    30
    5,138
    If you wanted to be super-ghetto-fabulous you could.
    You don't have to buy one with built in fuses. It just makes everything neater under the hood. You do need an aftermarket terminal though to fit the new wires you just added.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
  3. #33
    Feb 2006
    bay area, ca
    955
    Quote Originally Posted by johnecon2001
    Wait so you're saying I DO need the after market battery terminal but I just don't need the fuse? If I have the fuse does that mean I don't need an inline fuse on the power wire? What happens if no battery terminal? And using a battery terminal doesn't that mean there's no use for the ring terminals?
  4. #34
    Aug 2004
    Phoenix, AZ
    30
    5,138
    Quote Originally Posted by thai_creeper
    again, depends on the type of terminal you get. You stock one probably isn't going to get the job done is what I was saying. You still need a fuse on your main power line to the amps and the alternator positive to battery positive. You just don't need it built into the terminal.
  5. #35
    Feb 2006
    bay area, ca
    955
    Ohh okay, I'll probably just pick up a pair of battery terminals too..in which case I won't need those power wire terminals because I stick the power wire straight into the battery terminal right? Also, so if you get a fuse on the terminal does that take care (so you won't need) an inline fuse near the battery on the power wire running to the amps?
  6. #36
    bigrobrn's Avatar
    bigrobrn is offline Senior VIP Member
    Apr 2006
    Baton Rouge, LA
    169
    where is the best place to get an external fuse holder for 1/0 gauge wire?
    Thats a pretty big fuse holder.
    They call me the FireNurse
    Refs:
    Nebraskaz71
    FoxPro5
  7. #37
    Decado's Avatar
    Decado is offline CarAudio.com Elite
    Jul 2005
    Minneapolis, MN
    1,121
    Quote Originally Posted by bigrobrn
    http://www.knukonceptz.com/productDe...m?prodID=FH-20
    The Rest Of My System:
    -Orion HCCA-D2400 Amp
    -RE SX 15" Subwoofer
    -MTX Thunder 564 4-way amp
    -OlogyAudio Dayton RS Component Set
    -Sirius Satellite Radio
  8. #38
    bigrobrn's Avatar
    Apr 2006
    Baton Rouge, LA
    169
    is the fuse in the alt pos to batt pos absolutely necesary???
    even if NOT going through the fuse box???
    Thanks
    Refs:
    Nebraskaz71
    FoxPro5
  9. #39
    Jared530's Avatar
    Jared530 is offline Drop bombs
    May 2006
    Sacramento, Ca
    2,259
    i would love to do this, but reading the directions is like reading chineese to me. lol. anyone wanna come to my house and do this for me? lol
  10. #40
    taosd's Avatar
    taosd is offline Member
    Aug 2002
    Canada
    111
    Just did the big 3 on my 2001 Saturn L200... Unfortunatly it did not erradicate my Dimming woes. The dim only occurs for a split second when the bass hits, which leads me to believe that the Alternator CAN handle the power, it just takes that split second to kick in, perhaps the volage regulator on the alternato. Anywho, I'm bummed out that it didn't solve my problem...
    HU: Pioneer Premier F90BT
    AMP: JL 500/1v1
    SUB: JL 12W6V2 D4 @ 2 Ohms
    CAR: 2005 Nissan Maxima SL
    BOUGHT FROM: dropped_mazda, qcsfinest704
  11. #41
    Aug 2004
    Phoenix, AZ
    30
    5,138
    The Big three is not an end all be all to your problems.
    What size wire did you do the upgrade with? You're not even close to pulling over 1000w with your current system listed in your sig.. so perhaps you have some other issues with your car.
    You should take your car to AutoZone or Checker and get a free electrical system check up. They'll be able to tell you if you need a new alt or battery (most likely battery).
  12. #42
    taosd's Avatar
    Aug 2002
    Canada
    111
    I used 1/0 awg from KnuKonceptz. I do have 14.5 ish volts running accross the poles on the battery, and it only drops about 1 v when it hits.... but it does result in dimming. Come to think of it, the lights dim ever so slightly, for a split second when I use the power windows too (without the stereo on). Do you know if Partsource does free electrical system checkups?
    AMP: JL 500/1v1
  13. #43
    Aug 2004
    Phoenix, AZ
    30
    5,138
    Quote Originally Posted by taosd
    No idea. Try calling them on Monday.
  14. #44
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    how much 0g wire should i buy for this whole project, for a 95 accord?
  15. #45
    Aug 2004
    Phoenix, AZ
    30
    5,138
    Quote Originally Posted by Jared530
    Got a measuring tape?
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
