+ Reply to Thread
Page 28 of 63 FirstFirst ... 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 ... LastLast
Results 406 to 420 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #406
    Adamsauve's Avatar
    Adamsauve is offline Member
    May 2008
    michigan
    75
    Re: Official CarAudio.com Big 3 Thread
    so... why do u need a link between the chassis and block then?? to.. run power bewteen the two.. for no reason??
    im soo confused right now..
  2. #407
    xxBURT0Nxx's Avatar
    xxBURT0Nxx is offline Team Ramrod
    Jan 2008
    Denver, Colorado
    1,113
    The battery is linked via wire to the alternator that is why you upgrade this wire. The battery is grounded to the chasis of the car, that's why you upgrade this wire. The alternator is grounded to the engine block of the car, however you can help it get a better ground by adding a wire from the engine block to the chasis of the car!
    Refs: straightchillin, bad @ss chevy, Echo42987, dye4metal, nate2587, ThomasG, nismos14, AK SloPok
    Quote Originally Posted by wishbone View Post
    Just get over it my friend, the alternator does not charge the cap, period.
    WB
  3. #408
    dman4486's Avatar
    dman4486 is offline Paid to Post
    Jan 2008
    Central, SC
    9,333
    Quote Originally Posted by Adamsauve View Post
    you must have a complete circuit....just doing the positive is still choking the circuit on the negative side
    the circuit between alt and bat goes alt + to bat+, through the bat, then bat - to chassis/frame, and then from the chassis/frame to the block which is where the alt is grounded
    Auto: 96 honda passport 3.2L v6 4X4 5sp
    Big 3 pics--THE MAV--THE RSD's--MY VLX
    Rices Creek Pics
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
  4. #409
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    ...the alt case grounds to the engine block, and battery to frame, but to lessen the resistance between the two grounds, you install a larger gauge wire between the battery's ground (frame) and the alternator's ground (engine block)
    Rices Creek Pics
  5. #410
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    Quote Originally Posted by jco1385 View Post
    i still say that you do not need to go from engine to chassis if you go from engine to battery and chassis to battery. it's redundant.
    agreed, I went from alt case to battery then battery to frame
    Rices Creek Pics
  6. #411
    Adamsauve's Avatar
    May 2008
    michigan
    75
    okay i get it.. i dont think they explained the alt was grounded to engine block n e where.. thank you!
  7. #412
    J31Rob's Avatar
    J31Rob is offline CarTune Netwerk
    Nov 2006
    Indiana
    11,043
    3 Post(s)
    jco is helpful!
    | www. facebook .com/The.Funk.765 |
  8. #413
    Adamsauve's Avatar
    May 2008
    michigan
    75
    okay one more thing...
    i dont think my alt is connected by a bolt, more like a thing wire.. is this what they are talking about??
    because hooking up a 4g wire to a like.. 14/16g wire is bad right??
    Boston Acoustic SPG555-2
    Boston Acoustic GT-28
    97 TA 5.7
  9. #414
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    is your alternator not bolted to the engine? please post a pic if it isn't.
    do you mean someone has used bailing wire to attach the alt to the engine?? h/o where are you from??
    edit: michigan? i was hoping at least arkansas...
    But for realz just follow whats been posted. it's been beat to death for 28 pages. surely the alt is connected via a bolt. post if you cant figure it out
    ^^^^or a pic so we can laugh at your alt mount
    Rices Creek Pics
  10. #415
    Adamsauve's Avatar
    May 2008
    michigan
    75
    hahahha im not saying its not bolted..
    but i dont think the bolt receives or gives off any power...
    i have to connect like a small plastic connector.. is that what i connect it to??
    why would i put power to a bolt that doesnt do anything??
    97 TA 5.7
  11. #416
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    you are not putting power to the bolt....the alternator is grounded through the bolt
    if you don't have the ground, the alt will not have a complete circuit thus no output
    Rices Creek Pics
  12. #417
    bass-aholic's Avatar
    bass-aholic is offline CarAudio.com Veteran
    May 2008
    New York
    2,014
    :d
  13. #418
    Adamsauve's Avatar
    May 2008
    michigan
    75
    so its grounded through the bolt.. does that mean your using the grounded power instead of the actual alt power?
    im so confused.
    97 TA 5.7
  14. #419
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    I will find a diagram for you....maybe
    Rices Creek Pics
  15. #420
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    im so confused.
    if you break the + or -, then there is no flow and without flow there is no voltage
    Rices Creek Pics
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
