+ Reply to Thread
Page 25 of 65 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 ... LastLast
Results 361 to 375 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #361
    JeffM's Avatar
    JeffM is offline Senior VIP Member
    Jan 2008
    NL, Canada
    294
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by jco1385 View Post
    for reference:
    BIG 3
    alt + to battery +
    engine block to - battery post
    - battery post to chassis/frame
    that is all
    I thought it was
    alt + to battery +
    Block to chassis
    Battery - to chassis
  2. #362
    JeffM's Avatar
    Jan 2008
    NL, Canada
    294
    Here is a picture of my engine block. There are 2 bolts which I could use to ground from but both are really corroded and looks like it may be difficult to remove and clean. Righth behind the engine block is another piece of metal, which is not corroded. Could I use that as a grounding point?
    Attached Thumbnails Attached Thumbnails Official CarAudio.com Big 3 Thread-528.jpg   Official CarAudio.com Big 3 Thread-534.jpg
  3. #363
    CaptNKILL's Avatar
    CaptNKILL is offline Senior VIP Member
    Aug 2007
    PA, USA
    176
    Hmm... I can't really tell from the picture. The rusted parts don't look too good to me but the other one does. I don't know for sure though.
    I don't know if this is the proper way to do it, but I'd look for your alternator and follow the metal that it is connected to. It should pretty much be a part of the engine block. Follow the metal that the alternator is directly connected to. If it leads to that bolt you pointed out in the second pic then that one should work fine. If there is anything real obvious separating the two, it may still work but I'd look for one more directly connected to the electrical parts of the engine.
    But remember, I'm not a mechanic... I don't know what that bolt does. If your engine blows up after you take it out, don't blame me.
  4. #364
    CaptNKILL's Avatar
    Aug 2007
    PA, USA
    176
    Quote Originally Posted by snb778 View Post
    i just dont understand how bat- to chassis is diff. than batt- to block.. block is attached to the chassis isnt it
    There isn't any difference.
    Check the first post in this thread. The tutorial specifically says "Chassis to Engine Block".
    Besides, where does the battery ground\negative get its "ground" from?
    The chassis...
    Its all the same thing, its just that if you connect it to the battery ground you'll probably need more wire, and one of the goals of the big3 is short grounds.
    EDIT: Whoops, I misunderstood what you said. I thought you meant block to batt - was the same as block to chassis.
  5. #365
    JeffM's Avatar
    Jan 2008
    NL, Canada
    294
    So instead of going from the block to the chassis, can I go from alternator to chassis? And if so then what part of the alternator can I connect to?
  6. #366
    CaptNKILL's Avatar
    Aug 2007
    PA, USA
    176
    Quote Originally Posted by JeffM View Post
    I don't really know.
    Don't try to complicate things man. Its really not that hard.
    Just find your alternator, look at the main huge piece of metal its connected to (the engine block), find a bolt on that piece of metal, and ground that to the chassis.
  7. #367
    05AztecRed's Avatar
    05AztecRed is offline Senior VIP Member
    Aug 2006
    Tempe, AZ
    188
    1 Post(s)
    NO!
    You go from Alternator positive to battery positive ONLY... You DONT go from alternator ground to chassis.
    Most(if not all) newer alternators have a molex connector that has the ground wire built into it, therefore you CANT go from alt. ground to chassis.
  8. #368
    CaptNKILL's Avatar
    Aug 2007
    PA, USA
    176
    Quote Originally Posted by 05AztecRed View Post
    NO!
    Right.
    I just suggested using the alternator as reference because it will most likely be attached to the main part of the engine block you need to ground to as opposed to a heat shield or something.
  9. #369
    dman4486's Avatar
    dman4486 is offline RememberedHowToChangethis
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    NO!
    even if you have a molex connector, the alt is still attached to the engine block and the block to frame....so why would you not be able to ground the alt to frame
    Autos:
    '12 Audi A3 S-Line TSI 6MT
    '96 Honda Passport 3.2L v6 4X4 5sp
    2015 Victory Cross Country Tour 106
    2015 Ford Escape Ecoboost
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
  10. #370
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    wow, you guys like to take the easiest **** and make it hard. the neg post of the battery is the grounding point (take it off, and you have no power. this is how i know...)
    so you would be better off going to the neg battery post with the engine (alt) ground, as well as the chassis (frame) ground. and with both of those hooked up you achieve the engine to chassis ground, seeing as the chassis and engine are both grounded at the neg post.
    ps, Molex connector or not, the frame(case) of the alternator is its ground
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  11. #371
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    I understood this, but wanted to know why aztec made the statement
    Autos:
  12. #372
    JeffM's Avatar
    Jan 2008
    NL, Canada
    294
    Quote Originally Posted by CaptNKILL View Post
    That seems to be a little better to understand. im going to take a picture to post so maybe you guys can help me figure out where to connect the wire to.
    So heres a picture. Is the metal piece that is attached to the alternator the block? And Can I just pull that bolt out to ground to?
    Attached Thumbnails Attached Thumbnails Official CarAudio.com Big 3 Thread-495.jpg
  13. #373
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,862
    4 Post(s)
    644 Post(s)
    any bolt will do (as long as you dont take something apart and fvck it up). i used the alt mounting bolt.
    i release myself for liability if you fck something up.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  14. #374
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    I am sorry, but i can't help but laugh at your question.....the ENGINE BLOCK is what is being referred too!! If you have no clue what an engine block is, you should not open your hood
    Autos:
  15. #375
    WrenchGuy's Avatar
    WrenchGuy is offline CarAudio.com Veteran
    Sep 2007
    East Tawas, MI
    2,023
    I think the simplicity of this upgrade was indicated in like the first 3 pages...lol
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
