+ Reply to Thread
Page 21 of 65 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 ... LastLast
Results 301 to 315 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #301
    Feb 2008
    Sarasota, FL
    133
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by myjaja View Post
    Ok, I just bought a 130a ho alt. Im gonna do the big 3 with 0 gauge.
    first question: what size fuse do I use for it?
    second question: Do I connect the old wires to the terminals or leave them disconnected?
    thanks
    A lot of people are going to disagree, but Ohio Generator told me use as big as I want but only use 4 awg for the alt to batt pos because anything bigger would not fit properly on the alt post and would just overheat. They said leave the existing wire intact and do NOT fuse it. I've been debating this in other threads but since I had the electrical 100% professionally done and the fact that they have been building alternators for 30 years for this purpose... I listened to them.
  2. #302
    bigmack2007's Avatar
    bigmack2007 is offline Senior VIP Member
    May 2007
    Montgomery, AL
    328
    alright i have a question. i drive a jeep grand cherokee which is a unibody car. im going to use 1/0 gauge wire from the positive alt to the pos battery and from the negative battery to the frame. do i need to connect the chassis to the engine block? sorry im new to this.
  3. #303
    dbhittin's Avatar
    dbhittin is offline Banned
    Apr 2002
    Van...Wa
    33
    5,828
    did mine today with fosgate power wire.. only took 25ish mins..
  4. #304
    XxSuperAdamxX's Avatar
    XxSuperAdamxX is offline CarAudio.com Elite
    Mar 2006
    Bay Area, CA
    962
    Too many post to read, but just curious. The 300 amp fuse from positve alt to positve battery, if that fuse was to blow. Can I even start my car?
    Car: 2003 Honda S2000
    Sub: Diamond D3
    Amp: JVC ???
    Fronts: Polk Audio ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
    Reference: theitalianjob76, ssj2xxgotenxx, mhuynh, wong05tsx, bourboncollecti, budahbuddy803, sxkicker89, matrxx dude, mhyde71, outspoken, Nickatina, NewAgeKing
  5. #305
    Dingleberry's Avatar
    Dingleberry is offline pǝʇǝ1ǝp ǝʌıʇǝ1dxǝ
    Aug 2007
    A rock over the ocean
    234
    Quote Originally Posted by XxSuperAdamxX View Post
    You can jumper it. But you'll be running off the battery, so the distance you travel may be limited.
  6. #306
    Mar 2006
    Bay Area, CA
    962
    Whaaat.....that's krazy. So is it even common for a 300 amp fuse to blow?
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
  7. #307
    Aug 2007
    234
    Not usually but if it does, it'll be something catastrophic.
  8. #308
    Mar 2006
    Bay Area, CA
    962
    I see...so do I HAVE to disconnect my stock alt pos to bat pos. Or can I just attach the 1/0 gauge on?
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
  9. #309
    Aug 2007
    234
    Add on to your existing wiring and replace it with 0 gauge. Just run some wire loom over it. The engine bay gets pretty toasty. And make sure it clears everything hot, e.g. exhaust manifold, valve covers etc.
  10. #310
    Mar 2006
    Bay Area, CA
    962
    So...should I disconnect the stock or leave it on?
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
  11. #311
    Aug 2007
    234
    Since your car's fairly new, just add the 0 gauge power cable to your alternator. Leave your stock wiring in place and add onto it. Unless you're going to keep the car for awhile. Then by all means, replace everything.
    But either way, electricity will find the path with least resistance. So even if you add a bigger power cable and the stock wiring's still in place. The current will flow through 0 gauge cable. Just by being easier to go through. Also if you disconnect everything some systems might malfunction.
  12. #312
    Mar 2006
    Bay Area, CA
    962
    thanks man. I think i'll just add it on.
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
  13. #313
    Mar 2006
    Bay Area, CA
    962
    I don't want to be 2 hours away from home and my car not work and find out that i need a fuse to start my car. =P
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
  14. #314
    blackbonnie's Avatar
    blackbonnie is offline The Revolution
    Jan 2007
    Grand Rapids, MI
    10,146
    then dont put a fuse in your wire
    HU - Pioneer 800prs
    Mids - Peerless HDS nomex 6.5's
    Highs - Seas Prestige Alumi-domes
    Front Stage Amp - Sundown 100.4D
    Sub - SA-12
    Sub Amp - Saz-1000D
    Wire - Knukonceptz, Kicker Hyperflex
    Blackbonnie References/Feedback
  15. #315
    Mar 2006
    Bay Area, CA
    962
    but...I just bought a new incline 1/0 fuse.
    Sub: Diamond D3
    Amp: JVC ???
    Rears: N/A
    H.U.: Alpine ???
    Deadener: N/A
    Battery: Stock
    Car Alarm: Hornet
    Wires: ???
    RCA: ???
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
