+ Reply to Thread
Page 19 of 63 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... LastLast
Results 271 to 285 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #271
    Jacobman's Avatar
    Jacobman is offline CarAudio.com Elite
    Dec 2005
    CA
    499
    Re: Official CarAudio.com Big 3 Thread
    Alright the stuff is shipped and on the way, woot. Stock fuse is 100a so i figured 100a for the 1/0, any problems here?
    Alpine CDA-9847
    Alpine PDX-2.150
    PG RSd65cs
  2. #272
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    Just a thought, I'm running 0/1 out to my amps (then distro'd to 4ga). I know its overkill, since I'm only running ~800 watts, but what gauge should I use for my big 3? I have tons of 4 gauge lying around, and dont want to buy more 0/1, would I be safe to just run 4? or maybe dual 4?
  3. #273
    Jacobman's Avatar
    Dec 2005
    CA
    499
    yes 4 would be better than stock for sure.
    Alpine CDA-9847
    Alpine PDX-2.150
    PG RSd65cs
  4. #274
    slappinX's Avatar
    slappinX is offline throw your diamond in air
    Aug 2007
    Bay Area, CA/SJSU
    23
    310
    quick question,
    if were to use 0/1 gauge from the alt to bat. would it be safe to do two runs of 4 gauge for the grounds? i have quite a bit of 4 gauge and since i have a CRX i do not need a lot of length in the alt to bat. i do not want to buy more if i really do not need to.
  5. #275
    motox_727's Avatar
    motox_727 is offline Member
    Nov 2007
    Omaha, NE
    125
    looks good
    Head Unit: Pioneer DEH-P4800MP
    Components: soon to be kicker ks series
    Amp: Kicker ZX1000.1
    Subs: 2 Kicker 12" L5's
    Box: Dual 12" Ported
  6. #276
    miker's Avatar
    miker is offline CarAudio.com Veteran
    Oct 2007
    Wayzata, MN
    5,326
    Does it help to only do parts of the whole thing? B/c I don't really want to spend all the money it would take to run a wire from the trunk to the alt. Right now the pos. and neg. battery wires are very big, I'm not sure the gauge but they are quite large...
    So basically I'm asking, would it do anything to just do the last step? And would you want to be using 1/0g for this? or would 4g work? And why do you need to go from engine to "non-essential" and engine to chassis?
  7. #277
    taysextreme's Avatar
    taysextreme is offline Want some Come get some
    Dec 2007
    jersey
    324
    there were three wires going to my + bat term before i did anything. I was thinking about adding a 3 0ga input t block and run one to the alt+, one end to the rear, and the last end to a 300a anl fuse then to the + bat term. This will eliminate 1 o ga wire going to the bat as well as eliminate the 2nd inline fus to the alt.
    But is this a good ideal??????
    Eclipse cd7200mkii w/iPod adapter
    1 t152 comp set, 3x t1652 full range sets, 2 8 punch mids, & crescendo tweets)
    2 lvl 5 18s tuned to 35hz
    2 sprinter 370's(front) 6 deka 9a31s(rear bank)
    3 dc power 260sp alts
    mids/highs 2 t600-4, 1 t600-2
    sub stage soundigital sd8k
    REF: Spulla, Dbeez, dwrecked, ds autosports/ also 900+ feedback on ebay name: taysextremepitbulls
  8. #278
    PWNED's Avatar
    PWNED is offline Senior VIP Member
    Dec 2007
    Hooksett,NH
    170
    THis i what i will be doing for my big 3.I will be running a 1500watt rms mtx w/ a FI Q.
    So you have from the alt-battery positive.
    Then from block to chasis.
    Then from batt neg-chasis.
    I will be using the same chasis bolt is that ok?Also I will be fusing the alt-batt wire for extra precaution.I will be using a 200amp fuse for that all being done with 0gauge.
  9. #279
    WrenchGuy's Avatar
    WrenchGuy is offline CarAudio.com Veteran
    Sep 2007
    East Tawas, MI
    2,027
    Can you ground the engine and battery to the same chassis ground? As above!
  10. #280
    Troydb's Avatar
    Troydb is offline Member
    Nov 2007
    Down South
    113
  11. #281
    backthepack's Avatar
    backthepack is offline Stuntin' Is A Habit
    Aug 2007
    Drexel, NC
    604
    so can you just add additional 1/0 wire and not have to replace the old wire... just add extra??
    828CA
    1995 Toyota 4Runner SR5
    Coming Soon
    1988 Toyota Celica GT Convertible
    Headunit:Pioneer DEH-1400
    Front Stage:ID CTX65CS
    Front Stage Amp:PG 8.0.4
    Sub:SS Reference 12"
    Sub Amp:PG 6.0.1
    Hyperflex 4awg
    17" ICW Racing Wheels
    Bought From: Truckstoy, Speedfreak28, riogigalo, slammed
    Sold To: dirtyg, bigmandengo, adio, mastergunsx15
  12. #282
    bigandbadranger's Avatar
    bigandbadranger is offline Junior Member
    Nov 2007
    omaha
    22
    how do u do the big three on an older ford with the 2 plugs that go into the alt? grounds are easy to do but not the alt to battery?
  13. #283
    IDSkoT's Avatar
    IDSkoT is offline Resonating Reticular
    Jan 2008
    Miami, Florida
    6,276
    Quote Originally Posted by bigandbadranger View Post
    Same question, I think.
    Here's pics:
    Now designing / building boxes.
    (Only building sealed and aero port boxes.)
    PM me.
    Feedback Thread
    Refs: MSW Danny, atsaubrey (great seller), ampjunkielikeme, wgsj_fortvalley, tEh koRnDog, bad @SS chevy, Nismos14 (who is the man. )
  14. #284
    Nov 2007
    omaha
    22
    i believe on yours the single wire that bolts to the back of the alt is the one you upgrade. u have what ford calls a 2g 0r 3g alt. mine has only 2 plugs on it
  15. #285
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,035
    2 Post(s)
    i have the same alt. this is the wire to upgrade. i'll take a pic tomorrow when it's not so dark
    it's a Ford 3G alt, btw
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
