+ Reply to Thread
Page 18 of 63 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... LastLast
Results 256 to 270 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #256
    regal8r's Avatar
    regal8r is offline I <3 my CRX
    Oct 2005
    Lincoln, NE
    26
    9,829
    Re: Official CarAudio.com Big 3 Thread
    Quote Originally Posted by sandmanll06@com View Post
    i had a question. OK for the big 3 can i use power wire also for ground.
    power and ground wire is the same exact thing
    copper is copper is copper as long as it is the same AWG size
    1990 Honda CRX HF
    Mods: 239k mile, bonestock mod and rusty door weight reduction mods
    Bragging Rights: 47mpg
    Quote Originally Posted by 99gtxgolfer View Post
    OMFG!!! ^^^^^ regal ftmfw
  2. #257
    Mac11's Avatar
    Mac11 is offline MacGyver
    Dec 2002
    Outside Chicago
    29
    1,115
    Just got a new car so I'm doing this all over. Only this time I am having a bit of a problem. On this car (04 Mazda RX-8) My line runs from the alternator to the main fuse on the underhood fuse block then to the (+) battery terminal. So I have 2 different runs for this. Ok, no big deal. I have all the wire in place and I'm ready to button everything back up and when I re-connect the (-) terminal to the battery the main fuse that I just spoke of blows and sparks jump from the terminal. Anybody have any advice or ideas?
    "I'm craving carrots but all I have are these cookies!" -Rdub
    "HEY!! I stopped sellin pot after my first senior year!" -SD
  3. #258
    funkdoktor's Avatar
    funkdoktor is offline Senior VIP Member
    Jul 2007
    honolulu, hi
    291
    i wish this had pictures on page 1.
    VEHICLE - 2003 Jaguar X-type 4 door Sedan
    HEAD UNIT - Alpine - IVA - W200 double din
    COMPONENTS - Pioneer - ts-c520prs x4
    SUBWOOFER - 12 Inch Image Dynamics Idmax d-4
    ENCLOSURE - 2.0 cu. ft. @ 30hz
    POWER - Optima Red Top Battery
    Optima Yellow Top Battery
    AMPLIFIERS - Alpine - PDX - 4.150
    Alpine - PDX - 1.1000
  4. #259
    Mac11's Avatar
    Dec 2002
    Outside Chicago
    29
    1,115
    Quote Originally Posted by funkdoktor View Post
    its easy if you just get under your hood and look. it becomes pretty obvious. big single wire that goes from your alternator to your battery (or main under hood fuse block), big wire that goes from negative battery terminal to the chassis, and big wire (or braided strap) that goes from the motor( or intake manifold) to chassis. If you don't under stand this, you probably shouldn't be under the hood of your car.
  5. #260
    tremor1127's Avatar
    tremor1127 is offline Mental Member
    May 2007
    tx
    267
    Quote Originally Posted by Mac11 View Post
    x9
  6. #261
    nawgee's Avatar
    nawgee is offline Senior VIP Member
    Jul 2007
    Valencia
    171
    ok so im confused...my stock amp only pushes out about 85-90....if i do the big three will this increase my ampage
  7. #262
    SyKo13's Avatar
    SyKo13 is offline Bewb Saving Lawn Tech
    Oct 2005
    Coachella, Ca
    25
    16,538
    Current, not amperage
    Ņơßóđŷ Ģĭ√ễş Ǻ Ðäми, Ұỗữ Ħā√ề Ťő Ţǻҝĕ Ĭŧ.
    £îvè ƒơ® $ơmè†hîñg, ơ® dîè ƒỗ® ñỗ†hîñg.
    Quote Originally Posted by azbass View Post
    the sub was a pain in teh *** to get too.. and is mounted backwards upsidedown flipped over.
    Need some brick work done? Lawn need mowed and/or trimmed? Need some stucco work done? Then you're in luck because I am your man!
    WETBACK FOR HIRE!!!
    HANDJOBS, $5 each PM me for details.
  8. #263
    hasa68mustang's Avatar
    hasa68mustang is offline Senior VIP Member
    Mar 2006
    Central Florida
    248
    Quote Originally Posted by SyKo13 View Post
    actually I gained 7 amps at 2k... I only had a 8-10 gauge wire running from the alternator though. I did the same test earlier in the day and managed 98 amps, twice and reded it again after I did the 2 gauge to the battery and it came up to 105 both times. I dunno if thats freak of nature or what but both times all acc. were off as well as air and such. Im gonna go do the grounds now that I have the terminals, and see if it does anything else?
  9. #264
    cotjones's Avatar
    cotjones is offline CarAudio.com Veteran
    Feb 2007
    Wilmington, NC
    4,160
    Quote Originally Posted by vorgath View Post
    I don't suppose anyone carries those power distribution terminals, for the side mounted terminal GM batteries ?
    scoche makes them! i had to get them they screw in! you can get them at walmart just look hard for them
  10. #265
    jesse59672's Avatar
    jesse59672 is offline Member
    Aug 2007
    OKLAHOMA
    111
    Well i'm fixing to do this on my girlfriends saturn. Luckily, this will only be a 5 hour project or something. The idiots at Saturn (gm's practical joke) decided to put the alternator under the motor behind the power steering pump.
    Anyways my question is where do i get crimps? She also has the side post battery..
  11. #266
    Jacobman's Avatar
    Jacobman is offline CarAudio.com Elite
    Dec 2005
    CA
    498
    Alright my alt does ~100 amps and i wanna do the big3 with 1/0 wire. I am confused on what size fuse to get, how high can my alt spike? Would a 200amp fuse be fine?
    Alpine CDA-9847
    Alpine PDX-2.150
    PG RSd65cs
  12. #267
    Mesto's Avatar
    Mesto is offline Member
    Apr 2007
    Chesterfield
    124
    any pics of the BIG 3 being done on a DODGE RAM TRUCK?!!?!
  13. #268
    funkdoktor's Avatar
    Jul 2007
    honolulu, hi
    291
    quick question................why would i need a fuse from batt to alt???
  14. #269
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,852
    you dont need a fuse , I havent ever used one ALT to BAT
    Keep in mind it is a hot wire,so try not to short it out
  15. #270
    Jacobman's Avatar
    Dec 2005
    CA
    498
    Well i am still stumped on the fuse size for the 1/0 run. My stock fuse for the alt is 100a so im just gonna go with 100a for the 1/0, any problems here?
    Alpine CDA-9847
    Alpine PDX-2.150
    PG RSd65cs
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
