+ Reply to Thread
Page 13 of 63 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 181 to 195 of 939
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #181
    LeofromtheH's Avatar
    LeofromtheH is offline sneaker head
    Apr 2006
    houston,TX
    3,099
    Re: Official CarAudio.com Big 3 Thread
    that wire looks like spagetti. i bet it's super easy to work with. i had a somewhat hard time twisting and turning the welding supply wire to where i wanted it. here's some pics
    fuse on other side of those zipties
    dirty hands ftl
  2. #182
    iwanturmags's Avatar
    iwanturmags is offline Member
    May 2006
    asfsdf
    63
    Ok so Battery ground to chassis.
    Alt Pos to Battery pos.
    Engine block Neg to Chass.
    Is that it in lamens?
  3. #183
    da12b's Avatar
    da12b is offline Member
    Jun 2003
    Maui, Hawaii
    107
    yep, you got it.
    Ride: 1998 Honda Accord EX Coupe
    HU: Alpine DVA-9681
    Epicenter (in dash)
    Aphex Processer by Kove Audio
    Capacitor: 1 Frad Rockford Fosgate (monitor top)
    Amp: MTX 405 (5-ch.)
    Front: Boston Acoustics Pro60
    Rear: Boston Acoustics SX95
    Sub: 1 (one) Eclipse SW8122DVC (12 in. sub)
    Added the "BIG 3"
    Load Boss Alternator (180 Amps)
    One HC1400 Kinetik Battery (using as main battery)
  4. #184
    May 2006
    asfsdf
    63
    I read 8 of the 13 pages and did not find an answer to: my alternator is only 105 amps, does have a low power alternator negatve the effect of The Big 3? I mean it doesn't seem like it would but better safe then sorry.
  5. #185
    Mar 2004
    Frostburg, MD
    32
    1,941
    I wouldnt call that low power. Many people run off 60 amp alts all day long, and still do the big 3. I have a 70 amp in my civic.
    03'CivicEx (5spd)
    Premier 880PRS
    Rainbow SLC6.5 (front)
    Boston SL60 mids (rear)
    2X PG RSD 12'
    Rockford Power 851X 4chan
    Concept CD-2410 Mono
  6. #186
    theothermike's Avatar
    theothermike is offline I HAVE NO LIFE, CA = LIFE
    May 2006
    Tampa
    1,557
    informed from a guy with much more intellect then me that i need 2 fuse holders on the alt to batt run. 1 near alt, 1 near batt. that way where ever the short is coming from, im safe.
    question is why wouldnt 1 work? in middle, or more towards battery?
    Mike-
    System:
    Fronts:ID Oem's & TBI Hdss Front Amps: Sundown Sax 100.2 & 100.4
    Subwoofer: 2x 12" Fi X D4s Sub Amps: Sundown Saz 1500D
    Headunit: Alpine CDA-9887 Batteries / Alternator: Powermaster / Mechman
    Deadener: Raamat BXT Ensolite Alarm: Clifford 50.5x
    References:
    -Premieraudio-Sundownz-Iamamp3pimp-Kpr10is-Jmanpc- MemphisLove-Greekpower-The 727 Kid-Gixxer9-Mobieous-Audiobahnuser18-Thewes-Steveyhustle-Gymfreak101-go_go_thrash
  7. #187
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    30
    5,138
    He would be correct in a dual battery situation where power is running both ways (to and from each battery). In this case though, power is flowing away from the alternator towards the battery. Thus only one fuse, in the middle is required.
    And don't let some of these hippies tell you you don't need a fuse. EVERY car already has a fuse on the existing alternator wire in the fuse box. Its marked "alternator".
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
  8. #188
    phenryiv1's Avatar
    phenryiv1 is offline Custom user title
    Nov 2006
    Martinsburg, WV
    549
    I read most of this thread, but after a few pages of the same things over and over again, I gave up.
    I am SURE that somewhere in this thread, at least one of these questions are already answered, but "Search" just led me back to the thread as a whole...
    1, Will upgrading my battery terminals help with this effort?
    2, Are there any other grounding points that I might want/need?
    3, If I have a 3-4 foot run of 1/0 from batt to alternator, what amperage of fuse do I need?
    Thanks!
  9. #189
    Team Hammer's Avatar
    Team Hammer is offline Senior VIP Member
    Dec 2006
    Dallas, TX
    355
    Quote Originally Posted by phenryiv1 View Post
    Thanks!
    Adding Battery Terminals That Can except 1/0 and #4 makes it easier to wire.
    Battery Neg is the best choice then Frame or Engine.
    1/0 can be 250amp or 300amp.
    Also fuse the battery to Dist block run. Install the fuse as close to Battery as you can.
  10. #190
    tebo7's Avatar
    tebo7 is offline Member
    May 2006
    calexico ca
    46
    I have 2 Rockford 12" Stage 3 in my Honda Accord.
    When i turn the volume up the lights don't dimm.
    Does The big 3 will help to get more power to the amp?
    do i need to do the big 3 ?
  11. #191
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Quote Originally Posted by Team Hammer View Post
    Thanks. I think that I found batt terminals that hava a single 1/0, a single 4, and (2) 8 ga. holes. That will be perfect for my application.
    What do you mean the batt to d-block run? My 4-gauge run will go to a single 4 channel amp, and of course it will be fused at both ends. Is there another d-block that I should be using?
  12. #192
    hotbodkev's Avatar
    hotbodkev is offline Junior Member
    Nov 2003
    wilmington,NC
    29
    Quote Originally Posted by tebo7 View Post
    doing the big 3 wil not hurt it will only help you. do it.
  13. #193
    da12b's Avatar
    Jun 2003
    Maui, Hawaii
    107
    Icon14 Re: Official CarAudio.com Big 3 Thread
    If you want more power, get a bigger amp. The "big 3", to my understanding, will decrease the internal resistence, therefore making the voltage drop less. If you upgraded the "big 3" and the battery, and your lights still dims, you might want to consider getting a H.O. alternator.
    HU: Alpine DVA-9681
    Epicenter (in dash)
    Added the "BIG 3"
  14. #194
    Dec 2006
    Dallas, TX
    355
    Install a fuse from battery, Then the Dist Block should be a fusable type. I use ANL that takes Two 1/0 in and Two #4 outs. Mine are Pos/Neg built-in to the block.
    The way it works is You have Two Pos inputs and Two Neg Inputs 1/0 or #4 with a barrel Reducer, All in the same block. I use this type to break the wire size down for branching off.
  15. #195
    phenryiv1's Avatar
    Nov 2006
    Martinsburg, WV
    549
    Alright, I have an arguement that I need you guys to help me settle.
    After reading ALL 13 pages, it says in here numerous times to fuse to the wire, not to the alternator. Fair enough- I did that. I posted my pics and my writeup on a forum specific to my vehicle. In one of the pics, you can see my 200A fuse for the batt--->alternator wire. That sent people into a tizzy. Their argument:
    Quote Originally Posted by First Sentra Guy
    Is that a 200A fuse there? WTH would you need a 200A fuse. As good as no fuse. I use a 100A fuse w/ no problems whatsoever...
    I responded that I had read on here and on sounddomain to fuse to the wire and not to the alternator. His response:
    That makes no sense. If your alternator goes to hell and spikes 150A say good buy to the electical componets of your car.
    Then, a second guy chimed in:
    Quote Originally Posted by Second Sentra Guy
    Just want to say that he (First Sentra Guy) is right here. In my recent accident I had a wire going from alt+ to bat+ and something shorted out in my electrical system and set the engine on fire (right on the alternator). I can't help but think this might have been because of this extra wire (which was not fused) and a 200A fuse is gonna do about the same.
    So it got me thinking- WHY do we fuse to the wire and not to a rating just above the rated output capacity of the alternator? Since in theory, anything ABOVE the rated output from the Alt SHOULD blow your factory fuse, you have effectively sidestepped that safety device (the factory fuse) and now we have exposed the OEM electrical components to a spike or surge that it is not designed to take.
    I want to think that the advice that I get on a car audio forum is more accurate than that on a general automotive forums, as it applies to 12V matters, but I wanted to see if anyone here could give me some supporting info on WHY we fuse to the wire, regardless of the factory wiring and electronics capacities.
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
