+ Reply to Thread
Page 12 of 65 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 62 ... LastLast
Results 166 to 180 of 968
Reload Thread: Official CarAudio.com Big 3 Thread
  1. #166
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Re: Official CarAudio.com Big 3 Thread
    From what I can see, it's all your pictures so go ahead.
    There was someone who actually grabbed my pics and used them without my consent awhile back until I banned the forum that was using them from my image hoster.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
  2. #167
    evan's Avatar
    evan is offline Senior VIP Member
    Jul 2005
    Canada
    419
    I'm planning on doing the big 3 on my 1980 Malibu and I'm trying to figure out where the factory wires go.
    There is only one wire coming off of the positive terminal of the battery and it goes to the starter.
    The wire that looks like the power to the alternator runs into a loom that goes into the cabin under the dash.
    I don't know if this helps, but here is the label on the alternator.
    I wasn't able to get the car jacked up enough to see the starter, but is it possible that the positive cable goes from the battery, to the starter, into the cabin, and then back out to the alternator? Is that normal? Is there any harm in running a second wire directly from the battery to the alternator and leaving the stock wire in place?
  3. #168
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Honestly? Who cares where the stock wires go. Remember, you're just adding to the wire already there.
    Follow the three points and add your own wire.
    And just as an FYI, the Alternator probably goes to the fuse box, the power wire is fused and then runs to the battery.
  4. #169
    StealthKill's Avatar
    StealthKill is offline is hungry
    Sep 2006
    OK
    1,578
    My HU seems to flicker(lights flicker on/off) and I was noticing a slight voltage drop on the dash. Think the big 3 would fix this/help solve it?
  5. #170
    JunkTitleGolf's Avatar
    JunkTitleGolf is offline Senior VIP Member
    Aug 2006
    Corydon, IN
    156
    How is your head unit grounded? The big 3 will help some with dimming. Or at least it did for me. For your headunit it could all be in the grounding itself. Heard that you should always ground to bare metal and not use factory ground unless it is a bolt or something of that sort.
  6. #171
    Sep 2006
    OK
    1,578
    Allright, thanks. Ill just ground it myself, it is using the factory ground atm...I think.
  7. #172
    Ruffy's Avatar
    Ruffy is offline Death to the salad eaters
    Apr 2006
    Las Vegas, NV
    37
    380
    Question for all.
    Everyone says Dont take away Just add.
    What about on the alternator? What would be the point of fusing a 1/0ga cable going to the alternator if the original stock 8ga cable is still hooked up to it. If something goes wrong wont it fry the 8ga cable? Meaning id have to fuse that one as well to be safe. Or would it take the path of lest resistance ie the 1/0ga connection all the time.
    _______________
    For Sale, PM me
    Comps : Rainbow Audio SLC 265
    Subs : Diamond Audio D6 12" Subs X2
    Amp 1 : Hifonics ZXi 6006 AB Amp
    Amp 2 : Hifonics BXi 1606 D Amp
  8. #173
    Mar 2004
    Frostburg, MD
    37
    1,937
    Why do you need a fuse, or would want to put on a fuse? If the stock wires are not fused, why would u need to put one on with a bigger wire, and easier path for electricity to travel?
    03'CivicEx (5spd)
    Premier 880PRS
    Rainbow SLC6.5 (front)
    Boston SL60 mids (rear)
    2X PG RSD 12'
    Rockford Power 851X 4chan
    Concept CD-2410 Mono
  9. #174
    Saucy's Avatar
    Saucy is offline Junior Member
    Oct 2006
    Vallejo, CA
    29
    I was reading and you guys say add 0 guage but leave stock wires and it will help more current flow. Do you think it is possible to replace the stock wires with 0 guage wire and also add the big 3 with 0 guage wire????? So you would have your stock wires 0 guage then also have the 3 extra. Is this possible? Will it help even more?
  10. #175
    lil azn 06's Avatar
    lil azn 06 is offline Senior VIP Member
    Sep 2005
    Houston Texas
    30
    388
    Last time i checked, current will go more where the bigger wire is.
    There is no point in changing out the stock wire for 0 awg and also doing the big 3 as well. Unless you are running tons of current past the 0 awg limit then i would see why you would need more wires/thicker ones.
    Stock wires are fused, in the fuse box. Not putting a fuse and current is too high for the wire it could cause the wire to melt/overheat/fire.
  11. #176
    lil azn 06's Avatar
    Sep 2005
    Houston Texas
    30
    388
    Quote Originally Posted by Ruffy View Post
    Question for all.
    The stock alternator wire is fused. Its said in the post above.
  12. #177
    phenryiv1's Avatar
    phenryiv1 is offline Custom user title
    Nov 2006
    Martinsburg, WV
    565
    6 Post(s)
    I am SURE that somewhere in this thread, at least one of these questions are already answered. "Search" just led me to the thread as a whole...
    1, Are crimp terminals just as effective as screw terminals for this "modification?"
    2, Will changing my battery terminals help with this effort?
    3, Are there any other grounding points that I might want/need?
  13. #178
    AJ²06's Avatar
    AJ²06 is offline 8====D ---> ( | ) = win
    Jul 2006
    DFW, USA
    10,189
    I have officially laid the BIG 3 to rest now...
    ITS officially done in my car with all top notch wiring...
    14.45 voltage... [drops during beats of course]
    http://www.myspace.com/unknownbelow
    Refs: Showrides|IonSQL x2|mattmcss|QtrHorse x2|DaGh0st|bjfish11
    حَتَّى إِذَا اجْتَزْتُ وَادِي ظِلاَلِ الْمَوْتِ، لاَ أَخَافُ سُوءاً لأَنَّكَ تُرَافِقُنِي. عَصَاكَ وَعُكَّازُكَ هُمَا مَعِي يُشَدِّدَانِ عَزِيمَتِي.
    Ebay:aj06silver
    Quote Originally Posted by Reson8 View Post
    Much as I shudder at the thought of potentially seeing your *****, writing caraudio.com on your dick would kick ***. Que the joke about only being able to get up to "CAR" on it....
  14. #179
    AJ²06's Avatar
    Jul 2006
    DFW, USA
    10,189
    PICS tommorow.
    Ebay:aj06silver
  15. #180
    AJ²06's Avatar
    Jul 2006
    DFW, USA
    10,189
    Ebay:aj06silver
+ Reply to Thread
  1. The Official Type R Thread
    By justchillin in forum Subwoofers
    Last Post: 11-16-2010, 01:19 AM
