Results 1 to 7 of 7
Reload Thread: 1 Batcap 400 Series vs. 2 1-Farad Capacitors
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    36
    1,875
    Icon14 1 Batcap 400 Series vs. 2 1-Farad Capacitors
    Which would be better to use with my current all 4-gauge power and ground cables and MMATS D300HC amp - one batcap 400 series or 2 1-farad capacitors with bussbars?
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    in simple terms--------- the 2 caps
    HectorZ's Avatar
    HectorZ is offline Member
    Dec 2002
    Salinas, CA
    36
    53
    how ?
    look at the specs on this bad fella
    http://www.batcap.net/Model400.html
    A question:
    if I rewound my amp with my, currently, 600 watt setup, to say 180 ampers...
    would I still "need" one of these capacitor things ?
    ODELE !! http://www.inandout.com
    1989 BMW 750iL
    Deck: Nakamichi MB100
    Front: Rainbow Professional CS 365 P3 3-Way Components
    Rear: JL XR650 CSi Components
    AMPS: 2 JL 300/2 1 JL 500/1
    Sub: Adire Audio Brahma 10
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    Originally posted by HectorZ
    how ?
    ya just look at em....it should tell you it isn't a good idea
    A question:
    no
    Geminidj2000's Avatar
    Geminidj2000 is offline The Bad Luck Kid
    Aug 2002
    Denver
    581
    how much are u gonna be running total?....im preaty sure there are 2 farad capacitators our there 1 farad per 1000 watts if your running 2000 just get 1 2 farad cap
    1996 Ford Explorer
    H.U. Stock
    Front : stock
    Back: Stock
    Subs: 2 Image Dynamics IDMAX v3.
    Amp: Hifonics Hercules at 4 ohms (450 watts)
    soon to come
    Kick Panles
    Clear corners
    Altezza Taillights
    200A Alternator
    componets
    Jdg784's Avatar
    Jdg784 is offline Yep..I'm God
    Oct 2002
    Suwanee, Ga
    33
    723
    Just go ahead and get your alt rewound, cheaper..more effective..and just ..well better
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,027
    1 Post(s)
    267 Post(s)
    Re: 1 Batcap 400 Series vs. 2 1-Farad Capacitors
    If I were you, for now I'd do neither. I don't think you'll have a problem at all. If you do, then look into what you need to do to fix it.
