Results 1 to 2 of 2
Reload Thread: Installing 2 1-Farad Capacitors with MMATS Amp
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    36
    1,875
    Icon14 Installing 2 1-Farad Capacitors with MMATS Amp
    Okay, currently I have a 4-gauge power and ground connection with a 100-amp circuit breaker. Shortly, I will be receiving a MMATS D300HC amp for my HCCA 12's. I only have a 1-Farad cap. However, I will probably get 2 new 1-Farad caps with bussbars. Now, what should I do? Should I just go with the 4-gauge power to the cap and then to a fused distribution block and connect to the power on the amp? Or, should I use the 4-gauge power to a "T" distribution block and then use the 2 4-gauge power cables to the cap and then to a fused distribution block and finally to the amp?
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    Re: Installing 2 1-Farad Capacitors with MMATS Amp
    try to get the cap as close to the amp as possible if you can. no distros
