Results 1 to 9 of 9
Reload Thread: 4 ch amp help
    snaphook's Avatar
    snaphook is offline Junior Member
    Oct 2002
    MN
    4 ch amp help
    Hi all,
    I just got my stuff back after someone jacked all my equipment. Except I upgraded to a 800watt 4channel amp, and I'm hooking it up to a Bazooka RSW DVC 12" sub. I got everything hookedup but the sub isn't hitting right. It seems to be off a lot, and if I turn up the gain it gets a little louder but it isn't very loud at all, not even close to how my 12" rockford sounded with a little 300 watt amp running it. I have a 8 guage ground, which is the min. for my amp, it that too small?
    All the connections seem to be in order, not sure what else could be wrong... my uncle sold me the stuff and told me I could bridge channels 1&2 and 3&4 from my amp to the 2 voice coils on my sub, is there something I'm missing? Because something is really wrong here, and if I turn my bass boost on my sub snaps at me.
    I guess what I'm asking is how would you guys wire a 4 ch amp to a single DVC sub? Because I'm doing it wrong, or I have bad equipment.
    Thanks in adavance
    snaphook's Avatar
    Oct 2002
    MN
    TTT!
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    What's the impedence of the subs coils ? And does the amp have seperate gains for the front and the rear channels ? Let me know
    5 % equipment
    90 % install
    5% beer
    snaphook's Avatar
    Oct 2002
    MN
    I believe the speaker is 4ohms, and yes the amp has 2 gain controls, one for ch 1 and 2 and one for ch 3 and 4, I thought I could bridge it into 2 channels and hook one up to each voice coil...
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Yes you should be able to. That's why I was asking what impedence the coils were. Most 4 channel amplifiers when bridged can only handle a 4ohm load. I'm trying to pinpoint the problem. Sounds like the sub might be overpowered. Let me keep thinking
    5 % equipment
    90 % install
    5% beer
    snaphook's Avatar
    Oct 2002
    MN
    The amp is a Power Acoustiks Fire&Ice 800watt x4 if that helps, they dont make them any more they revamped it and changed the name to "Sapphire" now. I appreicate your help. I will take any idea or thought on the subject.
    Also its not like I have the gains cranked up to the max either. When I turn the key on the bass boost is off and the gains are turned all the way down. I put my hand on the sub and I can feel it moving a little but really can't hear anything. Then I slowly turn the gain up, it gets a little lounder but not much.
    The speaker moves weird too, like it's breathing, you know sucking in and out real hard. This happens when moving the gain up.
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Now it's really sounds like the sub is over powered. Is it a tube or is the sub in a box ? If a box what kind ?
    5 % equipment
    90 % install
    5% beer
    snaphook's Avatar
    Oct 2002
    MN
    I have the sub in a box, it is a MLB mobile audio or something like that, as far as brand.
    It's not ported or anything if that's what you mean. The sub spec said it was good for 400watts RMS and 500 peak. So I may be pumping to much into it?? If that's the case is there an alt. wiring config so I can just bridge one channel to the sub. I thought for sure that amps never really put out what they say on the box so I thought the sub would work fine.
    I didn't pick out the sub, my I just left it up to my uncle, he is a wholesaler of electronic equip. So I figured he knew what would be best for this set up. I'm starting to wish that I just kept the same stuff I had before.
  9. #9
    Corsica's Avatar
    Corsica is offline CarAudio.com Veteran
    Jan 2002
    Ft Huachuca, AZ
    33
    3,997
    It truely sounds over powered. Try dropping ur gains abit and the bass boost, maybe a diff sub here as Bazooka isn't the best except for their tubes. Try a diff higher RMS sub or a diff amp and see if it works better??
    J
    "A man doesnt win a war by dying for his country. He does it by making the other poor dumb son of a beyotch die for his." Patton
    No system installed, but getting all the parts together.
    J
