Results 1 to 3 of 3
Reload Thread: Finding ideal enclosure volume w/ Fs, Qts, Vas etc ??
    slaphappy's Avatar
    slaphappy is offline Junior Member
    Oct 2002
    Manassas, VA
    34
    19
    Ok, I thought the sub would have a recommended volume for a sealed enclosure... NOPE. I have some books but they don't help. These are the specs in the manual:
    Fs = 27Hz
    Qts = 0.30
    Vas = 3.2 Ft^2
    Qes = 0.32
    Qms = 5.0
    Sd = 490cm^2
    I don't know what any of this means. My book says:
    fob = Fs/Qts ... so Fob = 90
    Vof = Vas * Qts^2 ... so Vof = .288
    The manual then says to always make sure you make the enclosure 10% larger than required. Vof = 0.317? Woofer internal volume = .19 Ft^2
    So... 0.507 is the volume needed?
    The manual keeps using ft^2 (feet squared). Isn't it ft^3 (feet cubed)?
    HELP ME PLEASE
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    Re: Finding ideal enclosure volume w/ Fs, Qts, Vas etc ??
    Fs = 27Hz
    Qts = 0.30
    Vas = 3.2 Ft^2
    Qes = 0.32
    Qms = 5.0
    Sd = 490cm^2
    HELP ME PLEASE
    Download winisd from www.linearteam.dk, then input these parameters. It'll do the math for you, so you don't have to be concerned with the extra figures.
    slaphappy's Avatar
    Oct 2002
    Manassas, VA
    34
    19
    Thanks for the tip! I just downloaded winisd, plugged the numbers in, and presto.
