Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Installing First Amp (*Noob Questions*)
  1. #16
    then00b's Avatar
    then00b is offline Senior VIP Member
    Sep 2005
    VA
    37
    391
    Re: Installing First Amp (*Noob Questions*)
    Nope. I got it as a refurb from Ikesound and cant find the manual online. Thanks anyway.
  2. #17
    zenkar's Avatar
    zenkar is offline Member
    Jan 2006
    new jersey
    119
    wow great thread! i was gonna ask the same questions!
    I have another question though... i think my car has a stock little amp under my back seat.. ill be leaving the interior speakers as is for now... but ill be getting a new headunit and im worried about what to do next? leave it alone and just connnect to the headunit or take the amp off? please help! and if i do take the amp off how can someone explain the process of getting the amp off and speakers to the HU.
  3. #18
    zenkar's Avatar
    Jan 2006
    new jersey
    119
    bump
  4. #19
    stones's Avatar
    stones is offline Senior member
    Dec 2001
    Sask
    41
    2,174
    11 Post(s)
    Quote Originally Posted by zenkar
    There is installation kits available for most vehicles that allow you to connect a new HU to a factory amp but if you want to run directly from the HU you will need to run the speaker wires from the HU directly to the speakers, replacing the factory connections.
  5. #20
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,027
    1 Post(s)
    267 Post(s)
    Quote Originally Posted by then00b
    Also, do most cars (I have a Mazda3 s if it matters) have a hole for the power wire to go through? I havent looked at my car yet. Also, I only run one set of + and - wires from the amp to the sub correct if I am trying to wire one 12" Type R Dual 2 ohm to one ohms? Thanks.
    A hole for the power wire "can" be tricky to find. Some cars will have an unused grommet or two that you can just poke a hole in to get the wire through. That's as easy as it gets.
    On others you have to find a bundle of wires or a cable going through the firewall and run your wire through its grommet. That can be a pain.
    Worst case scenario is when there is no possible hole already there that can be used and you have to drill your own. On 3 different cars I've never had to do this.
    For your speakers you can do one of two things. First of all - you don't have to use both speaker terminals on that amp - they're the same connection.
    This begs the question - why are you running 1100w to your type R?
    Up.
    Also, If I am going to be adding a second amplifier and I own a distribution block, does it matter which amplifier has its power wire connected to the battery? I would assume it wouldn't.
    They both should be connected to the battery -- you'd run a large wire from the battery to the distribution block - which would split it into two (usually) smaller wires for each amp.
    '04 Chrysler Town & Country (it was cheap and I have a family)
    • HU: Stock - Scosche SLC-4
    • Comps: Lanzar Opti6c w/Opti400x4d
    • Rear fill: Stock
    • Sub: Lanzar Opti1232D 3cf 29hz w/Zed Opti1000.1d
  1. Question about ohms and bridging...
    By Justinw303 in forum Amplifiers
    Last Post: 06-11-2005, 02:30 AM
  2. Installing an amp
    By Chowder Head in forum Wiring, Electrical and Installation Help
    Last Post: 06-10-2005, 10:05 AM
  3. installing amp
    By almo181 in forum Amplifiers
    Last Post: 12-05-2004, 11:59 PM
  4. Installing 2nd Amp To Speakers : Help Please
    By omnipseudo in forum Wiring, Electrical and Installation Help
    Last Post: 10-15-2004, 05:09 PM
