Results 1 to 4 of 4
Reload Thread: Need help with amp choice.Please help?????!!!
    bowtiefan's Avatar
    bowtiefan is offline Senior VIP Member
    Sep 2002
    East TN
    44
    192
    I have narrowed my choices down to two mono amp manufacteres.If anyone has any experience with either of them please post you likes and dislikes.Im having a hard time choosing.The amp will be powering two 12" Infinity Reference series subs in a sealed box.The sub specs are 300w RMS,1200w peak,SVC 4ohm.Here are the amps im considering:
    PPI PCX 1250=500w x 1 @ 2ohms with 12v input,.02 THD, sig.-noise 110db
    Hifonics Zeus Z1000d=750w x 1 @ 2ohms, input voltage unknown,.08 THD,sig.-noise 90db
    As stated earlier if anybody has any experience with either amp make,Please post your knowledge about them!!!! I would greatly appreciate it!!!!!!
    Jasontb2000's Avatar
    Jasontb2000 is offline Member
    Mar 2002
    alabama
    44
    117
    I use to run PPI amps. They are good clean amps, but so models lack BALLS. The 1250 is a class D and is a good amp for your set up. The HiFonics seems to be a little two much for subs with a rms of 300 watts. But I compare the Infinity subs with the sony xplod models, 200 watts rms and 800 max. It's just to big of a gap between the power handling ranges to be true. Rms ratings will almost always be half of the max power rating.
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    If I remember Hifonics hierarchy correctly that is the middle line.. Both MFGs make some very sweet amps most depends on what you wanna do.. I like the way HF makes em big and pretty tough but a lot of the time you sacrifice with THD to get that power. I would look more towards PPI personally generally cheaper reliability isnt an isssue and they are pretty clean..
    Mike
    Your friendly neighborhood subaru freak!
    bowtiefan's Avatar
    Sep 2002
    East TN
    44
    192
    Thanks for the help guys!.I 'm gonna take your advice and stick with PPI.....I'll let you all know how things work out when I get the amp and get it hooked up...again thanks.....
