Results 1 to 4 of 4
Reload Thread: first box build
    crakerhead's Avatar
    crakerhead is offline CarAudio.com Elite
    Apr 2002
    Richmond, VA
    680
    first box build
    hey all i'm building my first ported box. it's for a dd 9515. i got dimensions from dd themself. here they are :20" Deep, 15" Tall, 34" Wide. I'm not sure what the dimensions of the port will be. I need help on how to place the port wood inside of box. I'm making out of 3/4 mdf btw. When I go to place to get wood what dimensions should I cut the wood into? And what should the dimensions of the port wood be? Can you'll post pics boxes' inside. This way I can get an idea of what goes where and all. Thanks a lot everyone!
    crakerhead's Avatar
    Apr 2002
    Richmond, VA
    680
    it's all going in the back of a 1990 audi 80 sub will be powered by jbl 1200 at one ohm. dd says this is supposed to be a 4 cubic ft box. they didn't say what to tune it to though. but if you have dimensions for a 3 cubic ft box that would be great too to save some space b/c as of now i have no room what so ever. I'd actually rather a 3 cft box so it can actually move some air in the trunk.
    Jasontb2000's Avatar
    Jasontb2000 is offline Member
    Mar 2002
    alabama
    39
    117
    If your asking how big the port should be then you have opened a can of worms. It depends on what freq. you want the box porrted at. I can tell you that if your port was 3" wide the you should keep it at least 3" off the sides and bottom of your enclosure.
    crakerhead's Avatar
    Apr 2002
    Richmond, VA
    680
    well dd told me to tune it to around 45 hz. how do i know the dimensions?
