Results 1 to 3 of 3
Reload Thread: question abot buying an amp
    pcsafc's Avatar
    pcsafc Guest
    Hi, im not too sure about how to buy an amp
    Does the RMS of the amp needs to be equal
    or greater than the RMS of the sub???
    Or should i only check the peak watts of
    the amp and sub????
    Thanks
    natem33's Avatar
    natem33 is offline Senior VIP Member
    Jan 2002
    St.Paul, MN
    415
    If you're newer to car audio then you can pretty-much ignore the peak power rating. You've got the right idea of matching the RMS of amps and subs. RMS is the key number.
    Snapnakk's Avatar
    Snapnakk is offline Member
    Jan 2002
    MN
    34
    79
    Yes rms is the key but it is also good to get a little extra power if ya can but then you have to be careful with how high you turn it up and how high you put the gain on your amp. Most subs and other are underrated so they dont get blown are offen or thats kinda what i have found to be true.
    later
    Just Opionions, not facts
    dont get mad or beat me with an axe
  1. question about buying an amp
    By MikeCole89 in forum Wiring, Electrical and Installation Help
    Last Post: 11-22-2008, 04:37 PM
  2. Buying New Amp, General Question
    By Damien in forum Amplifiers
    Last Post: 07-03-2008, 06:43 PM
  3. Tech question about 2 chan. amp running 1 ch. at 2 ohms
    By crazydude133 in forum Amplifiers
    Last Post: 01-17-2002, 01:24 AM
  4. buying an amp
    By cjr in forum Amplifiers
    Last Post: 01-13-2002, 08:45 AM
  5. QUICK HELP I"M BUYING AN amp this week!!!
    By rpeterson57 in forum Amplifiers
    Last Post: 12-20-2001, 08:10 PM
