Results 1 to 14 of 14
Reload Thread: ok another wiring question
    jaygeorge1979's Avatar
    jaygeorge1979 is offline CarAudio.com Elite
    Aug 2002
    Corpus Christi
    600
    ok all u car audio junkiws this should be simple enough for you.....
    i have a pair of 4 ohm tweeters and i wnat to buy a pair of 8 ohm midranges.....
    i want to run a tweeter and a midrange on the same channel...my head unit can handle a four ohm load...will this work or will i be hurting my HU....how do u know???? what are the secret calculations.....thanks in advance
    Aug 2002
    Corpus Christi
    600
    wow u guys are fast........not lol jk but i still need some help
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    it is Tweeter X mid/ tweeter + mid
    4 X 8/4 +8= 2.6666ohms
    are you using a passive x-overs??? if so don't worry about
    Aug 2002
    Corpus Christi
    600
    i think i get it for the most part....but if 2.6 is less than 4 ohms then shouldnt I have a problem??? i do have passive x-overs but how does that make a difference??? someone please help i am an idiot lol.....
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    cause they are adding resistance to one or the other speaker depending on freq
    sforget's Avatar
    sforget is offline Junior Member
    Jul 2002
    Crowsnest Pass
    36
    Formula
    The formula for calculating impedance/resistance ratings (in your case) would be.
    using Ohms Law 1/R1 + 1/R2 = 1/Rt where R1, R2 = Resistance values
    RT = Total resistance
    1/4 + 1/8 = 3/8 = 2.6 ohms
    Car audio is:
    10% equipment
    70% Install
    20% Creativity
    and 100% attitude
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    Re: Formula
    thats just the raw drivers connected to a amp----------they have passive x-overs
    Aug 2002
    Corpus Christi
    600
    wow this crap is so confusing...is there some essay written somewhere explaining all this ohm crap cuase bits and peices of info arent doing it for me...thanks
  9. #9
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    just look around the net for laws of electricity
  10. #10
    Snow27's Avatar
    Snow27 is offline Junior Member
    Aug 2002
    Japan
    42
    No More Patience!!!
    Greeting's,
    I have had it with my amp, I have gone through 5 fuses and shorted out my amp. I have no clue where the light blue wire is susposed to go behind the stereo. I was told to the antenna but my reciever isn't labeled and I have two blue wires, I connected both wires but it sparked when I tried to attatch to amp, then when I finally attatched it my subs didn't work, can you make any sence of this before I go spend $200-to have everything professionally done. Thanks a bunch...
  11. #11
    Aug 2002
    Corpus Christi
    600
    hey dude first of all u need to post your question on a new thread (click on "new thread" on the top right corner of the main page) what u have done is posted a reply to my question, which only a couple of people will see...i will try to help but posting it elsewhere would be more efficient for U...dont worry i dont mind though...neway your problem is that u have a blue remote connect wire...it tells the amp when to turn on...u have an aftermarket stereo i am assuming...and you manuel should tell u which wire is the remote lead...the name is something like that...the blue wire from the stereo should be used for this or be used for a powered antenna...jsut read your manual it should help if u dont have the manual then look online for the manual...go to the online site. for example www.aiwa.com and most manuals are posted online...if still not then look online for a stereo wire diagram for cars similar to yours...this should help but still post this elsewhere for further assisatnce...
    gooooooose
  12. #12
    Jul 2002
    Michigan
    35
    73
    You have three choices of where to hook the amp turn-on wire or the,"light-blue wire", up to. ACC+(usually a red wire), Power Antenna, or sometimes there is a specific wire dedicated to the amp turn-on. But like jay said, do read your manual to find out for sure. But I would try hooking it up to the ACC+(accessory supply) if you have no clue. And of course be sure the wire you hook up to actually is the ACC+ wire.
    By the way, disconnect the negative terminal of your battery before connecting, or removing any components to and from your amp. You'll save many fuses, sparks, and injuries that way.
    1993 Volvo 850 GLT
    Alpine CDA-7875 27W.4(rms)
    Sony Xplod 190.2W(rms)
    2X JLAudio 10W3d4 w/custom box
    MBQuart components in front
    8 speaker system, 10 w/subs
    488 total watts(rms) of power
  13. #13
    Aug 2002
    Corpus Christi
    600
    word up to that my homie
    gooooooose
  14. #14
    Aug 2002
    Corpus Christi
    600
    hey here is a good one for you...my friends air conditioner was broken so I used that switch and power wire so that he could have a switch for his amp...dont ask me why he had an amp before AC down here is south texas it is hotter than hell....lol
    gooooooose
