Results 1 to 12 of 12
Reload Thread: How to install second amp with only one set of HU preouts?
    Aug 2004
    detroit
    30
    621
    How would I install a second amp to my head-unit if my head unit only has one set of RCA sub pre-outs?
    Eclipse, Auidopipe 3000.1?, JL Audio, Diamond Audio, Kicker
    References: PepsiFiend69, jl12w7inabox, pickup1, 88irocz, matt calgary, drubob23, bowens99gt, pesteele, unbonyr, pistons520, characterzero, showrides, RJ_22, Rocky 59, Guy022077, thadman, buckshot, mikeyb, grizzly, lowendtheory, lexani2002, lpmaster, 954runner, flakko, qtrhorse, DaveT, Live4SkimLC, Ridinhi, angrytrucker78, seth350
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,006
    1 Post(s)
    259 Post(s)
    Re: How to install second amp with only one set of HU preouts?
    with a couple of these...
    60ndown's Avatar
    60ndown is offline CarAudio.com Veteran
    Jun 2005
    ca
    3,590
    or buy an amp that has a 'straight thru' signal in-out?
    .::DuD3::.'s Avatar
    .::DuD3::. is offline EE in training
    Oct 2004
    Chesafreak, Va
    29
    4,530
    daisy chain the amps together
    Designated "Fast and the Furious" quoter.
    Pioneer 880prs
    PG Rsd 6.5
    15" Fi SSD w/copper coil
    Alpine PDX-1.600
    Alpine PDX-2.150
    Knukonceptz 1/0
    60ndown's Avatar
    Jun 2005
    ca
    3,590
    Quote Originally Posted by .::DuD3::.
    ^ thats what i meant?...daisy chain..
    Rattlebrain's Avatar
    Rattlebrain is offline alcoholic
    May 2003
    Amarillo, TX.
    47
    3,905
    2 Post(s)
    B.O.H.I.C.A.
    Quote Originally Posted by WhoSayWho? View Post
    I do not believe in drinking in moderation. Seems like a waste of potential.
    kuijo's Avatar
    kuijo is offline CarAudio.com Veteran
    Mar 2005
    TX
    31
    2,681
    how do the splitters effect the preout voltage? and the same for daisy chaining the amps, does the master amp boost the preout voltage at all for the slave?
    stones's Avatar
    stones is offline Senior member
    Dec 2001
    Sask
    40
    2,154
    Quote Originally Posted by kuijo
    It causes a slight drop in the voltage(less then 1/4 a volt), not usually enough to be audible unless your HU RCA outs have a really high ohm rating (over 1000 ohms).
    As for the master/slave amp, I don't know, never thought about it. I assume it would to ensure they both get the same exact signal.
  9. #9
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    NE Indiana
    4,058
    15 Post(s)
    takes 1 pair of RCA's and can split them into sub, front, and rear outputs for the amp. basically what my equalizer does i just spent more on it, funny to cuz i'm only using 1 amp....
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
  10. #10
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Double post............sorry
    Source Unit: Pioneer P9 combo
    Tweeters: CDT DRT-25 Silk
    Mids: CDT ES-5 (5.25")
    Midbass: CDT M6 (6.5")
    Subs: Pioneer TS-W12PRS
    Mid & Tweet amp: Pioneer PRS-X340
    Midbass Amp: Pioneer PRS-X720
    Sub Amp: Pioneer PRS-X720
  11. #11
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Stones is right...using splitters lowers your pre amp voltage. Using a pass thru from one amp to another does nothing to the signal voltage at all. It just passes it along (without fvcking with it) to the next amp in line. This of course is totally different from daisy-chaining.
    For example, my cd changer and XM tuner are all Pioneer P-Bus compatible. So I actually daisy chained the p-bus output from the xm tuner to the p-bus input of my changer then ran the p-bus cable up to my deck and they are now both connected and controlled by the p-bus head unit.
  12. #12
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    34
    5,137
    yeah but the drop isn't even noticeable to most DMM that don't have enough digit slots. so the audible difference won't be heard.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
  1. amp or HU power???
    By fearturtle03 in forum Head Units
    Last Post: 05-23-2005, 03:51 PM
  2. Amp vs. HU HELP
    By fearturtle03 in forum General Discussion
    Last Post: 05-09-2005, 03:31 PM
  3. Josh Camp 04 :: COMPLETE Install In 95 Neon w/ Pics
    By josh99ta in forum General Discussion
    Last Post: 03-30-2004, 12:32 PM
  4. GM HU wired for amp set up
    By Benbear24 in forum Wiring, Electrical and Installation Help
    Last Post: 03-27-2004, 04:53 PM
  5. Replies: 8
    Last Post: 01-27-2004, 08:09 PM
