Results 1 to 15 of 15
Reload Thread: Battery in the trunk
    paul83085's Avatar
    paul83085 is offline Senior VIP Member
    Jul 2002
    USA
    32
    468
    Hi i need to put the battery in my trunk for air filter reasons and my question is on the power cable from the battery in the trunk how far does that need to be away from the rca cables becase i dont think i can run them on the same side of the car
    mr4pto's Avatar
    mr4pto is offline Senior VIP Member
    Mar 2002
    GA
    35
    182
    Yes it is best to run your power wires on the other side of the car. If you have a really good set of RCAs you can sometimes get a way with having the wires close and not have noise but its still recommended to keep everything as far away as possible heh
    Headunit: Eclipse CD8443
    Front Stage: Boston Acoustics Z6
    Rear Stage: Boston Acoustics Pro 6.5
    Subwoofer: Dual JL 10W7 Sealed Enclosure
    Mid/High Amplifier: JL Audio 450/4
    Subwoofer Amplifier: JL Audio 1000/1
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    Re: Battery in the trunk
    No need at all to run your power wires away from your RCAs-----why do you need a second battery?
    paul83085's Avatar
    Jul 2002
    USA
    32
    468
    I do not need a second battery we are taking the battery out because the car was built with a larger than stock engine in it and we dont have any room for the air filter and if we take it out there will be room
    mr4pto's Avatar
    Mar 2002
    GA
    35
    182
    Re: Re: Battery in the trunk
    I was under the impression that you could get engine noise if your RCAs where close to your power cables . . . depending on the setup, RCAs, wires etc
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    I miss understood what you were doing --------- you moving the stock battery to the truck right?????? this might create alot on noise in your system------ in this case ----yes keep your RCAs away from this wire----- you better run a heavy --heavy --heavy gauge wire to the front. This is cause your starter is going to want ALOT of current when cranking----200+A
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    Re: Re: Re: Battery in the trunk
    in normal batteries up front cases ----no you don't need to keep you RCAs away from your AMP's power wire. When runing a battery in the trunk ----yes---- keep it away
    paul83085's Avatar
    Jul 2002
    USA
    32
    468
    Yeah the wire is some old weilding wire that my dad had so it is about 2 gauge its more than a inch thick and had to cut it with a hacksaw. Do you think this will be ok for it and does the gauge of the wire have anything to do with speaker noise at all. and how much is a good set of rca cables if this does go wrong i got a set in a kit from schorse or however you spell that think that will be good enough??
  9. #9
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    do you happen to know how many amps the starter pulls???? this is the determining factor for what size cable you need
    no
    I would make a set from cat-5 about $20
  10. #10
    blackgeltabs's Avatar
    blackgeltabs is offline Knowledge is Power
    Mar 2002
    Boston
    1,036
    2 Post(s)
    what kinda motor is in the car?? That will give you a decent idea of how much amps your starter draws. If not take it out and bench test it. Im assuming its probably around 60-100 amps, as long as the engine isent a diesl.
  11. #11
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    thats all they draw?? thought is was 100+ maybe 200A
  12. #12
    paul83085's Avatar
    Jul 2002
    USA
    32
    468
    um its a 3.1 180 horse
  13. #13
    Mar 2002
    Boston
    1,036
    2 Post(s)
    Im sorry it was along night, your starter will bench test at around 60-80!! In the actual car a 6 cylinder will draw around 160-200 amps. V8's draw 185-250 amps, and disel can be up too 400+ amps.
  14. #14
    paul83085's Avatar
    Jul 2002
    USA
    32
    468
    Dam then what gauge wire should i use to get the job done then??
  15. #15
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    1/0 gauge
