Results 1 to 7 of 7
Reload Thread: setting gains with or without inline crossover?
    Goldenknob's Avatar
    Goldenknob is offline Bored In Antlers
    May 2005
    Antlers, Ok
    544
    4 Post(s)
    I'm wanting to set my gains with a voltmeter.. but between my H/U and my amp I have a Sony XEC-505 electronic crossover that splits the 4rcs's from my H/U to 6 channels to go to amps. making the channels 2 sub, 2 mid, and 2 high. should I bypass this to set my gains then hook it back up as normal?
    cjjackson85's Avatar
    cjjackson85 is offline Banned
    Mar 2004
    Idaho
    33
    9,061
    Re: setting gains with or without inline crossover?
    Go through whatever you'd use during normal playback.
    Goldenknob's Avatar
    May 2005
    Antlers, Ok
    544
    4 Post(s)
    thanks cj...
    one more thought..
    when setting the gains in this style.. is this assuming that your amp is putting out a clean un clipping signal?.. how can you tell if it is clipping?
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    With an oscilloscope. Otherwise you need to either set the output voltage conservatively (below rated output) or have faith in the manufacturer's ratings.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    Goldenknob's Avatar
    May 2005
    Antlers, Ok
    544
    4 Post(s)
    heh.. sound advice.. thanks..
    think I"ll visit the local shops and see what they would charge to check till clipping gain setting just to be safe... unless of course it would be super expensive.. then I'll just play it safe
    theCybe's Avatar
    theCybe is offline sector three
    Dec 2004
    Columbus, OH
    6,004
    You'll notice a jump on the DMM; For instance;
    When gaining my BX1500d;
    I wanted 1000w @ 2 ohm;
    2000sqrt= like 44.72 something.
    So, attached the meter.
    If you twist the gain up, you might get a reading like 80.
    Now, 80 * 80 = 6400 / 2 = 3200 watts. Obviously incorrect.
    Clipped signal.
    Gain a volt or two under your calculation.
    Goldenknob's Avatar
    May 2005
    Antlers, Ok
    544
    4 Post(s)
    what we did (me and btmorris) we first gave it a nice fat 4 guage ground cable, from my smaller 14 guage. then played the 45hz test tone with no speakers hooked up to the sub amp, engine running.. my head unit was at 60/80 with bass and treble flat 0, had the crossover at halfway for the subs. was only getting about 17volts with the gain all the way up.. so we turned the crossover gain knob up to about 3/4 and the voltage shot up to about 50 or 60.. so we then turned the gain down.. we ended up with the gain at about 3/4 on the amp and the gain on the crossover at full with the boost on the crossover at 3/4 and the freq at 80 and below. this setting achieved a voltage of 31.6 out of one channel of the amp.
    to make sure we did the formula right
    Sqrt(2*500)= 31.6
    since I only have one gain knob then this set both channels for each sub..
    as stated by others.. it did seem a bit quieter, but with a tiny adjustment up to 66/80 it got plenty loud.
    and I left freedom to be able to adjust the crossover gains a little higher at a lower volume if I want more bass and less mids and highs.
  1. setting crossover settings
    By noob with an RS in forum Speakers
    Last Post: 01-26-2005, 10:46 PM
  2. setting components' crossover
    By noob with an RS in forum Amplifiers
    Last Post: 01-26-2005, 10:26 PM
  3. setting crossover settings
    By noob with an RS in forum Head Units
    Last Post: 01-26-2005, 10:10 PM
  4. Question about setting the gains for amp
    By biiqdanz in forum Amplifiers
    Last Post: 01-10-2005, 12:26 AM
  5. Need Help setting gains w/converter, and two amps!!
    By Casurfer99 in forum Amplifiers
    Last Post: 12-25-2002, 10:58 PM
