+ Reply to Thread
Results 1 to 7 of 7
Reload Thread: Sub/amp Qualification for mustang 2017
    baklulu19's Avatar
    baklulu19 is offline Junior Member
    Aug 2017
    Vancouver, BC
    Feedback Score
    Icon32 Sub/amp Qualification for mustang 2017
    So, I have planned to get "HDS3.112 Subwoofer"
    ( SoundQubed HDS3.112 )
    with
    "SQ-12LSVDD 12" Soundqubed Single Vented SPL Box"
    ( https://www.atrendusa.com/soundqubed...gle-vented-spl )
    pairing with
    "AudioPipe APCL15001D High Power Mono 1500 Watt Max Class D Car Amplifier"
    ( https://www.amazon.com/dp/B00BW54418..._yM2HzbQTR52AN )
    via
    "4-Gauge Amplifier Install Kit"
    ( 4-Gauge Amplifier Install Kit )
    and
    "NVX XPLOC2 High-Low converter"
    ( https://www.sonicelectronix.com/item...VX-XPLOC2.html )
    QUESTION - How is Soundqubed sub ? I have never experienced it. Can we compare it with Alpine subs or JL subs? Does any one has any similar setup? how is it ? I am only getting single ''12 inches sub, Will that be enough to feel the bass within car? I listen to hip-hop kind of music mostly. Will I need any extra Battery to run this setup? My car is brand new tho with head unit stock and everything stock yet. I'm not planning to upgrade head-unit any soon.
    Thanks in advance for visiting this post guys.
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,731
    17
    Feedback Score
    30 Post(s)
    2685 Post(s)
    Re: Sub/amp Qualification for mustang 2017
    many peeps don't think sq subs play deep or have any sq (ironic huh?) and those atrend boxes are tuned to like 40hz i checked.. some peeps have had problems with ap 1500's lately., how much power do u actally want u can get cab 1600 for $199 hugh amp very popular., u can get amp like mine $169 ppi p1k (tested @ 1162rms @1ohm) and it does 930 rms at 2 ohms (tested) it's better to get 2 or 0 g wire if u gonna run more than 1k (i have 4ga) but if u add 2nd amp u be glad u have the thicker wire.. check out those amps and look at sundown sa or FI ssd (made in us).. * NEW * CAB-1600.1 Amplifier - Car Audio Bargain * B-Stock* Sundown Audio SA-12 600W SA Series - Car Audio Bargain bstock is just as good as new but with a 30 day warrnaty new they $214 SSD Series - SSD12 | Fi Car Audio 12-Inch CUSTOM-PORTED MDF CAR STEREO SUB WOOFER ENCLOSURE 2 CU. FT. TUNED @ 32Hz | eBay
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    Jan 2017
    NC
    6,731
    17
    Feedback Score
    30 Post(s)
    2685 Post(s)
    also u listed nvx convertor u should look at nvx vcw 12 very nice sub $199
    2 ohms rule
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,186
    Feedback Score
    15 (100%)
    245 Post(s)
    7915 Post(s)
    hds lines wont play deep in that box. HDC lines will though so i'd jump up to the hdc3 if your main music goal is hip hop. Or american bass xfl if you are on a budget.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    kcr357's Avatar
    kcr357 is offline Senior VIP Member
    Aug 2012
    ft laud
    331
    Feedback Score
    1 (100%)
    1 Post(s)
    128 Post(s)
    If youre gonna spend x amount of dollars on a new amp, better to spend that same amount on a used amp from atrusted member on here. Shop wisely and youll get motr power and better reliability imo
    Sold to
    Bought from
    NinjaBass
    FasFocus00
    "If I was so worried about resistance I'd be unplugging the factory wiring harness, and checking resistance on every wire in my vehicle."
    kcr357's Avatar
    Aug 2012
    ft laud
    331
    Feedback Score
    1 (100%)
    1 Post(s)
    128 Post(s)
    FS: BB1350.1 good power!*!**!
    Here; unless im missing something this dude is giving this amp away
    Sold to
    Bought from
    NinjaBass
    FasFocus00
    Popwarhomie's Avatar
    Popwarhomie is online now Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,390
    Feedback Score
    11 (100%)
    66 Post(s)
    2501 Post(s)
    Check out the FU audio 1250 12" in a custom box. Also I would do Knukonceptz amp wiring kit as well over the Soundqubed. Go with the CAB 1600 amp over the Audiopipe too.
    I personally would do
    FU audio 1250 sub FU Car Audio, fu audio, fu car audio
    CAB 1600 amp * NEW * CAB-1600.1 Amplifier - Car Audio Bargain
    Knukonceptz amp wiring kit Bassik 0 Gauge Amplifier Installation Wiring Kit - Merchandise
    custom built box or this one if you can't build one FU Car Audio, fu audio, fu car audio
    Also does your car have the upgrade stereo system or base stereo. With the amplified system its little more than just a LOC.
    2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by XxAndreaxX View Post
    too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
+ Reply to Thread
  1. best sub + amp combo for under $300?
    By WiNnErPL in forum General Discussion
    Last Post: 08-15-2004, 01:25 AM
  2. Decent sub/amp combo for ~$200-250?
    By atldc in forum Subwoofers
    Last Post: 03-31-2003, 11:50 AM
  3. subs, amp, box for less than 700
    By nswartley in forum Subwoofers
    Last Post: 12-21-2002, 11:00 AM
Tags for this Thread
