Results 1 to 5 of 5
Reload Thread: [Completed] 2 18s ported design
    surreal's Avatar
    surreal is offline On my katy perry sht
    Jan 2010
    OK
    615
    2 Post(s)
    8 Post(s)
    Design by request for two custom 18" woofers. Specs were provided and 6 cubes a piece proved to work very well for the output the user was looking for.
    Enclosure is essentially 12cubes tuned to 30hz, and will work for many others doing two 18s setups.
    Dimensions: 48Wx24Tx33D
    If you are needing a design for two 18" subwoofers, you can purchase this design for immediate download here: 2x18s Vented enclosure - $15.00 : TheBoxHouse, Enclosure designs
    I do stuff
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Re: [Completed] 2 18s ported design
    Just curious why do people do dual chamber stuff like this instead of just a single chamber with a large slot port on the bottom?
    surreal's Avatar
    Jan 2010
    OK
    615
    2 Post(s)
    8 Post(s)
    Preference/look, ease of build.. I dont normally do the bottom port unless by request or is needed - either physically, or if absolute help is needed for best extension possible.
    I do stuff
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Idk I guess my only dip with it is that unless you have a lot of width you really gotta squish the subs in, like you can see the flush baffle is just barely getting the clearance it needs from the edges
    surreal's Avatar
    Jan 2010
    OK
    615
    2 Post(s)
    8 Post(s)
    It was close for the flush mount but the rest has good clearance.
    Oh, and also sometimes using a really wide bottom port make it too skinny and needs to be braced well. Its generally just more work.
    I do stuff
