+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Sundown U Series 12 Enclosure
    mattshady's Avatar
    mattshady is offline Junior Member
    Dec 2017
    Cherokee Village, Ar
    5 Post(s)
    When will box specs be available for the U12 D2?
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2704 Post(s)
    Re: Sundown U Series 12 Enclosure
    Quote Originally Posted by mattshady View Post
    idk but i'd guess it would be same as sa or x..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,785
    16 Post(s)
    2331 Post(s)
    Does sundown have a website?
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2704 Post(s)
    U SERIES
    2 ohms rule
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2704 Post(s)
    Quote Originally Posted by THATpurpleKUSH View Post
    i actually thought they weren't up yet cause i had looked couple weeks ago but they are up now
    2 ohms rule
    mattshady's Avatar
    Dec 2017
    5 Post(s)
    Yes I already have one. My SA12 was stolen so I thought I would Try the U series. I have it in the old SA 12 box now. Still waiting for it to break in be cause so far it doesnt hit as hard or as low as the SA.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,196
    245 Post(s)
    7918 Post(s)
    how much power do you have on it and whats the enclosure looking like?
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2704 Post(s)
    may need more break in time and power.. it should sound like a SA with the low end of a X (or that's kinda what they said anyway) that thing may need 1500-2k
    2 ohms rule
  9. #9
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,179
    44 Post(s)
    1398 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    It replaced the zv3... it will not sound like a X
  10. Likes Boomin_tahoe, macsdad liked this post
  11. #10
    Jan 2017
    NC
    6,766
    17
    30 Post(s)
    2704 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    just saying should be loud right? i knew it was a mix of a couple of there subs.. yeah it says similar motor to x that's where i got it at..
    2 ohms rule
  12. #11
    mattshady's Avatar
    Dec 2017
    5 Post(s)
    Im running an Orion XR2500.1D. Its birth sheet was 2977 watts at 12.6 volts so power isnt a problem. The box is exact specs off sundowns skethup blueprint.
  13. #12
    shredder2's Avatar
    shredder2 is offline CarAudio.com Elite
    Nov 2017
    Phoenix Az
    1,499
    42 Post(s)
    596 Post(s)
    Looks to me like between the extra displacements due to driver size, and extra port area... the box probably needs to be a bit bigger... idk exactly what would work without sitting down and modeling it up but with that much power and excursion you'll probably need 16-17in2^ft3 of port minimum.... maybe more.
    That Sa-12 box is .06ft3 smaller due to driver displacement differences right off the bat and the port is IDK how much undersized in port area... should be a totally different beast once boxed properly.
    Not sure how much extra port area you'll need but I'll look at it if you want... probably need a ton of extra port area with all the power you got.
  14. #13
    ronin1717's Avatar
    ronin1717 is online now Member
    Apr 2017
    tx
    135
    2 Post(s)
    52 Post(s)
    You should be able to tell the difference, not significant going from 12 to 12... but easily noticable ... I agree with @shredder2 more port area
  15. #14
    mattshady's Avatar
    Dec 2017
    5 Post(s)
    Yes please and thank you.
  16. #15
    shredder2's Avatar
    Nov 2017
    Phoenix Az
    1,499
    42 Post(s)
    596 Post(s)
    This one has around 37in2 of port and is almost 17in2^ft3... probably do a lot better than the box you've currently got, that's 2.21ft3 net tuned to 32hz or so.
    hmu if you think that is one that'll fit your vehicle.
+ Reply to Thread
  1. I've got my blueprints from PWK designs for a single 12" enclosure (Sundown X Series)
    By NIHL8ION in forum Enclosure Design & Construction Help
    Last Post: 04-25-2013, 01:13 AM
  2. re vlx series compared to sundown audio 1500 saz series
    By needthat22 in forum Amplifier Classifieds
    Last Post: 03-26-2011, 01:01 AM
