+ Reply to Thread
Results 1 to 13 of 13
Reload Thread: Mega Roll and upper bass
    XxAndreaxX's Avatar
    XxAndreaxX is offline Member
    Mar 2016
    spain
    77
    35 Post(s)
    Hello, I switched from an 8" 110RMS sub to a sundown X8 750RMS, both sharing the same enclosure.
    Found out, even if the first sub has at least 1/7th of the power rating, the upper bass sounds even stronger.
    maybe becuse, the actual X8 woofer surface is more like a 6 inch or even 5 (the rest is foam of surround).
    For me its not a problem, I don't like upper bass anyways, but maybe someone could miss it.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,335
    220 Post(s)
    7371 Post(s)
    Re: Mega Roll and upper bass
    Quote Originally Posted by XxAndreaxX View Post
    the x8 just doesnt like upper bass at all even if you order it without the mega roll surround. Even though people say it plays it fine and recommends them for someone that wants to play rock/metal... its fking hilarious how delusional they are.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  3. Likes macsdad liked this post
    Dislikes Hertz Mafia disliked this post
  4. #3
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    1,797
    36 Post(s)
    1101 Post(s)
    The x8 is an SPL 8".... the SA 8 is for daily lows.
  5. #4
    Jul 2016
    Michigan
    1,797
    36 Post(s)
    1101 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    So false. The x8 is more SPL woofer and the SA is for lower/daily use... I'm not a fan of the X8 but I do like the SA 8
  6. #5
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    879
    1 Post(s)
    227 Post(s)
    I bet that lower power sub can not play as low as the sundown
    If you stick a low power high qts sub in a small ported box it will preform well
    Suffocate that x8 in a small box and it won't
    What size is your enclosure and what is your port size
    Not that it will magically become amazing but you could be leaving a lot of output or bandwidth on the table
  7. #6
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,724
    107 Post(s)
    7517 Post(s)
    I bet something is wrong with the install. Either power or box. Or both.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  8. Likes Hertz Mafia liked this post
  9. #7
    Jeffdachef's Avatar
    Feb 2013
    15,335
    220 Post(s)
    7371 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    spl woofer or not doesnt have anything to do with lack of upper bass bandwidth. So far none of the X8 installs i've heard can play anything other than bass genres 30-50hz.
  10. #8
    Mímir's Avatar
    Mímir is offline Banned
    May 2017
    Lafayette,la
    117
    2 Post(s)
    57 Post(s)
    they bottom heavy. put them in a small higher tuned box helps but they are naturally efficiency down low.. one of the downfalls of the design..
  11. #9
    Jul 2016
    Michigan
    1,797
    36 Post(s)
    1101 Post(s)
    The X8 will play everything and is not bottom end heavy. So as stated above if the OP having problems with the way it sounds it's most likely the box and under powered. I would still pick an SA8 over an X8 any day of the week.
  12. #10
    Jeffdachef's Avatar
    Feb 2013
    15,335
    220 Post(s)
    7371 Post(s)
    the guy i know that run it has a pair on sundown saz 2500 at half ohm, box tuned to 3 cube 33hz. They tried to shrink the box and ended up at 2.5 cubes 38hz slightly helped but still overly weak upper bass response compared to their previous JL and shok industries subs. Its loud as balls for decaf etc but he hates that he cant play classic rock or spanish music. And yes even with lots of attempts at retuning the gain and EQ he still cant get them to play the range needed. While his old subs, all he needed was to raise the sub level by a few notches and he got what he needed.
  13. #11
    Jul 2016
    Michigan
    1,797
    36 Post(s)
    1101 Post(s)
    2.5cubes seems big of your not trying for lows. More like .75cubes per
  14. #12
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,389
    25 Post(s)
    1320 Post(s)
    Jacob has said himself that the sa8 is more suited to low frequency reproduction than the x8.
    Also, Jacob suggests .75 for the x8. Using boxes that much larger than suggested is going to pull resonance down.
    I know what you are talking about tho. I heard 2 x8 in almost 3 cubes tuned at 32, and it basically only played 25-40
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
  15. #13
    XxAndreaxX's Avatar
    Mar 2016
    spain
    77
    35 Post(s)
    my enclosure *****. but I love the way my X8 sounds. don't need upper bass at all.
+ Reply to Thread
