Results 1 to 5 of 5
Reload Thread: Got a e8 V2 Dual 2, 300 watts
    qguy's Avatar
    qguy is offline Member
    Nov 2016
    Philippines
    42
    20 Post(s)
    This is what i can work with
    Length : 36
    Top depth : 5.5
    Bottom Depth : 7
    Height : 10 inches
    Internal volume less the wood is around 1.5. cubic feet. What kind of port do I need ?
    Sundown recommends a ported 0.7 box, Will get better performance while using less power with the bigger box ?
    if a bigger ported box is much more efficient and goes louder, What kind of port will I need for 2 cubic feet box ?
    thanks
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,280
    41 Post(s)
    6050 Post(s)
    Re: Got a e8 V2 Dual 2, 300 watts
    What vehicle? What kind of music you listen to?
    @CSCStang can get ya a design.....actually, I just designed my 1st angled enclosure for a few 8's or 10's on Sketchup.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    qguy's Avatar
    Nov 2016
    Philippines
    42
    20 Post(s)
    4 door sedan.
    the box dimension I posted is what I can work with, I can go deeper but not longer
    Electronic/trance/80'z music
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    412 Post(s)
    2 Thread(s)
    973 Post(s)
    Your dimensions give you .84 gross. You'll need one 3" aeroport at 16.5" length for .75 net @35hz. Port would have to be side firing.
    Sent from my SCH-I605 using Tapatalk
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
    qguy's Avatar
    Nov 2016
    Philippines
    42
    20 Post(s)
    I just realized that the sub won't fit the dimensions
    Length : 36
    Top depth : 6.5 (was 5.5)
    Bottom Depth : 7
    Height : 10 inches
    Is there a formula I can use in excel to determine port dimensions once I provide cubic feet volume ?
    What is the max volume for a ported enclosure that I can use for this E8 D2 300 watts ?
